No speed gain at all with 48mm BBK
amazing4
Post by amazing4 »
This has probably been brought up before, but I gotta ask. I've got a 1986 Spree. So for Christmas I got a 48mm BBK. It came with the bigger jet. Easy install all the way around. Added the extra recomended oil to the tank so it's intentionally rich. Lost alot of take-off which I expected, but gained NO top speed at all. :cry: So after all that, it starts slower, still only tops out at 30 and smokes more! Bummer. So what gives? Is it possible that the exhaust is just loaded with gunk and it's not breathing? There are about 2200 miles on the scoot. I'm lost here and will take any help I can get..thanks.
spree-rider
Re: No speed gain at all with 48mm BBK
Post by spree-rider »
i'm not going to touch this thread. i will just EXPLODE. but you probably didn't break it in right. and a bbk doesnt increase your topspeed. that's what gears do. a bbk increases your torgue and actull power to spin gears.
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
Petrock's 1984 Spree
Post by Petrock's 1984 Spree »
The bbk will increase your acceleration and decrease your mpg. It does nothing for top speed. If you want higher top speed then do the front pulley mod or buy the aftermarket gears like spree-rider said.
The front pulley mod how to can be found on wikispreedia
In short, the bbk you got did exactly what it was supposed to do.
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
Post by eliteguy50 »
The BBK may be ported to run at a higher RPM (higher top ground speed) but the 48mm BBK is still being choked down by the stock exhaust and intake. When you let it breath, it will rev higher than the stock bore.
amazing4 wrote:This has probably been brought up before, but I gotta ask. I've got a 1986 Spree. So for Christmas I got a 48mm BBK. It came with the bigger jet. Easy install all the way around. Added the extra recomended oil to the tank so it's intentionally rich. Lost alot of take-off which I expected, but gained NO top speed at all. :cry: So after all that, it starts slower, still only tops out at 30 and smokes more! Bummer. So what gives? Is it possible that the exhaust is just loaded with gunk and it's not breathing? There are about 2200 miles on the scoot. I'm lost here and will take any help I can get..thanks.
If you lost take off, then something is screwed up, because the BBK, especially the 48mm, should help bottom end acceleration a lot. The no increase in top speed is not surprising as the 48 BBK needs more carb than the stock carb. The stock carb chokes the big end. It smokes more because you are stuffing more oil into the engine than the oil pump did by itself. Chances are if it reaches 30 mph the exhaust is most likely not the issue.
Do a compression test and let us know the numbers.
