Folks,
I bought a high performance variator from JaingWayne for my 93 Elite 50 SR. I have a couple of questions. First, it has shallow holes but it it does not have threads for the three screws attaching the variator backing plate. Am I supposed to cut those threads myself? I think I read somewhere about leaving the backing plate off. Does that make any sense?
Second, it looks pretty similar to the old one. What is the difference?
Thanks in advance,
Jim Moore
Variator Backing Plate Question (93 ELite 50 SR)
Re: Variator Backing Plate Question (93 ELite 50 SR)
why do you want to put on the plate? leave it off and it will perform better.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
you don't need the backing plate its just there to keep grease in which honda later decided was not necessary, infact the backing plate actually hinders top speed so toss it and skip the grease
p.s. if you grind down the sharp edges of the ramp plate your rollers will last longer
1985 aero 50
ported
custom exhaust
ruckus vario
1K polini clutch springs
hopefully nh80 powered soon!
ported
custom exhaust
ruckus vario
That's what I'm asking. You just leave the plate off? How do all the pieces stay inside? (Man, that question sounds dumb!)odinxxix wrote:why do you want to put on the plate? leave it off and it will perform better.
So, no plate and no grease! No kidding?!
Keep the plate off and mount variator with the boss and you will see how the pieces stay inside.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- Trafficjamz
Jim Moore wrote: How do all the pieces stay inside? (Man, that question sounds dumb!)
Not dumb.......The rollers simply have no room to fall out, after the belt is in place. like evilone said, you'll see when you put it together.
Well, that was simple enough. I jsut scored myself 5 mph! Thanks for the help fellas.
