needle setting
needle setting
Does the needle setting. Only effect idle flow? Running BBK with stock carb and 110 main with needle on bottom groove. Nasty hesitation on takeoff then smooths out. Would raising needle help takeoff but hurt temp at wot?
94 Elite S
De-restricted
Ruckus vari 7g
9:1 secondary gears
tai big bore 50mm
De-restricted
Ruckus vari 7g
9:1 secondary gears
tai big bore 50mm
Re: needle setting
try the middle groove or play around and see which notch gives the best performance it shouldn't make your temps go up at all it just gives more fuel at lower throttle positions so it will give better take off/throttle response
1985 aero 50
ported
custom exhaust
ruckus vario
1K polini clutch springs
hopefully nh80 powered soon!
ported
custom exhaust
ruckus vario
Re: needle setting
All you need to know about what does what and where with scooter carbs.
Re: needle setting
Awesome display. Thx !
94 Elite S
De-restricted
Ruckus vari 7g
9:1 secondary gears
tai big bore 50mm
De-restricted
Ruckus vari 7g
9:1 secondary gears
tai big bore 50mm
