needle setting
Posted: Sat Mar 26, 2011 12:04 pm
by bmccaffry
Does the needle setting. Only effect idle flow? Running BBK with stock carb and 110 main with needle on bottom groove. Nasty hesitation on takeoff then smooths out. Would raising needle help takeoff but hurt temp at wot?
Re: needle setting
Posted: Sat Mar 26, 2011 1:21 pm
by bc117
try the middle groove or play around and see which notch gives the best performance it shouldn't make your temps go up at all it just gives more fuel at lower throttle positions so it will give better take off/throttle response
Re: needle setting
Posted: Sat Mar 26, 2011 2:50 pm
All you need to know about what does what and where with scooter carbs.
Re: needle setting
Posted: Sun Mar 27, 2011 11:04 am
by bmccaffry
Awesome display. Thx !
