Testing Solenoid
keithhlars
Testing Solenoid
Post by keithhlars »
How do I tell if my solenoid is bad or it's something else. When I use a screwdriver to short out the two post on the solenoid the engine cranks over. I put a test light on the one post that should get 12v once I hit the start button but I get nothing.
Re: Testing Solenoid
Do you have the brake on? The power to run the solenoid comes from the brake light. The start switch supplies the ground.
