My 84 Spree pit bike got dumped and the exhaust seems to be plugged or highly restricted. Is there a problem if I cut it open, clean and remove everything inside then weld it back up? When I took it off and shook it, there was quite a rattle coming from inside.
It is only used as a pit bike, not on the street
Spree exhaust
Spree exhaust
keep smiling
Re: Spree exhaust
you probly knocked the baffles loose, if you can find a foot long drill bit you can slide it in through the rear and drill the baffles out
1985 aero 50
ported
custom exhaust
ruckus vario
1K polini clutch springs
hopefully nh80 powered soon!
ported
custom exhaust
ruckus vario
Re: Spree exhaust
How do you drill the baffles if they are knocked lose?bc117 wrote:you probly knocked the baffles loose, if you can find a foot long drill bit you can slide it in through the rear and drill the baffles out
I would suspect that he knocked loose a bunch of carbon build up in the muffler rather than the baffles.
Try this to cure it.
http://hondaspree.net/wiki/index.php5?t ... r_Cleaning
