Honda SA50 Elite S,SR 1988-1993 = engine same as aero 50?
- Goped
these two share the same engine right?
Re: Honda SA50 Elite S,SR 1988-1993 = engine same as aero 50
yep except 87-93
1985 aero 50
ported
custom exhaust
ruckus vario
1K polini clutch springs
hopefully nh80 powered soon!
ported
custom exhaust
ruckus vario
- Goped
87-93 has a different motor then?
That Variated AF05E engine casting was introduced in its long-run form to this country in the 1986 AERO. The '85 was similar but featured a 2-bolt intake port. The 05 continued mostly unchanged until 1993. What BC is saying is that ehe SE50 Elite model bowed in 1987, sold alongside the more Classic-styled Aero. The two shared the variated AF05E engine block. Different intake manifolds and even a split belt-cover on some Japanese and Euro models appeared over the years, but basically all parts interchange from 86-93.
Read What Engine Code... in Advanced Technical Docs for the whole sordid tale.
Parts interchange but there are some differences, like porting, variators, electrical plugs, intake manifold, carb, oil pump...
- Goped
ok, I will read that to get a better idea. I messaged the seller of this and he said it wont fit an aero. But it seems from what I am reading that it should fit. http://r.ebay.com/AId9AO
That seller is also a member of this board, Tazland001. If he says it will not fit, my guess is that the porting is different. I have no first hand experience with that kit though so I can't say for sure. The stroke is the same but the crank and case part numbers are different. I remember the case having minor differences but can't think of an example right now.scottorious wrote:ok, I will read that to get a better idea. I messaged the seller of this and he said it wont fit an aero. But it seems from what I am reading that it should fit. http://cgi.ebay.com/ebaymotors/Honda-SA ... _500wt_956
