Page 1 of 2
Exhaust options for se50?
Posted: Fri Apr 01, 2011 10:53 am
by TiffanySpree
Will other exhausts fit my newly acquired project se50? Say, one from an early sa50 up to 93?
Re: Exhaust options for se50?
Posted: Fri Apr 01, 2011 10:58 am
by Trafficjamz
This will fit if you can find one
LeoVince SP3
Posted: Fri Apr 01, 2011 11:21 am
by turtle13
With the SP3 getting harder and harder to find, doing what I did works great too as long as the pipe will fit under the plastics. Buy a Dio pipe, section the header pipe, then weld it all back together with the SE50 flange. The mounting points are the same, the only thing that is really alot different is the geometry leading to the jug.
of course these pipes are designed for a different engine, but they are close enough that it still makes a huge difference over stock. Plus when the LV pipe is officially gone, what other option are you going to have?
Posted: Fri Apr 01, 2011 11:28 am
by eliteguy50
Make sure it is an SP3 for af05e Honda engine.
If you are looking for stock replacement, the se50p pipe will fit but it will also restrict you. I know the '85-87 nb50 exhaust pipeswork well. I think the '88-93 sa50 pipe will fit but I have not tried that myself.
Posted: Fri Apr 01, 2011 11:38 am
by TiffanySpree
Thanks for the sp3 pic. I read about that but didnt know what it looked like. I want something better than stock as I will likely mod it. I'll post in the build section as the build makes progress. Wish I knew how to weld now. Maybe this is a good excuse to learn!
Posted: Fri Apr 01, 2011 5:01 pm
by evilone
TiffanySpree wrote:Say, one from an early sa50 up to 93?
It was years ago but i'm almost positive i did put a 88-93 sa50 exhaust on my 87 se50 and the fit was right on.
Posted: Fri Apr 01, 2011 5:26 pm
They're still around.
One size fits all SE/05, but the Aero needs a little washer shimmage to clear the bodywork and/or a fat tire.
Posted: Fri Apr 01, 2011 9:45 pm
by martynkim
LV SP3 well worth the search and the $$$ I have one on my SE50 wouldn't go without it!
Posted: Fri Apr 01, 2011 10:01 pm
by eliteguy50
Wheelman-111 wrote:Greetings:
Hmmm, maybe multiple members go in together to order all the pipes in one lot. Would that make it easier/save money through customs?
Posted: Sat Apr 02, 2011 12:53 am
by TiffanySpree
What's the estimated shipping to the US?
Posted: Mon Apr 04, 2011 12:52 am
IIRC I paid a total of around $150 in 2008-09. That's when the US Dollar didn't suck as bad...
Posted: Sat Aug 27, 2011 8:18 pm
by DERP
same question as first post...
the pipe that is linked on this page will work with a 87 SE50?
will it work with a SE50 wiht a 65cc big bore?
Posted: Sat Aug 27, 2011 8:35 pm
by martynkim
DERP wrote:same question as first post...
No reason that it shouldn't. It will perform even better with a 65cc. The stock bore takes awhile before it will hit.
Posted: Sat Aug 27, 2011 8:51 pm
by DERP
me gusta. the first pic in the link dident seem like the same pipe.
thanks for the help
powerband
Posted: Sun Aug 28, 2011 6:52 am
by evilone
DERP wrote:the first pic in the link dident seem like the same pipe.
Look under the picture..."pictures may look different"
