40 MPH Spree
- SpreeMadness520
40 MPH Spree
Why did my 86 spree run 10 mph faster without the aircleaner?
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- Trafficjamz
Re: 40 MPH Spree
SpreeMadness520 wrote:Why did my 86 spree run 10 mph faster without the aircleaner?
Because the old one was dirty?
- SpreeMadness520
Re: 40 MPH Spree
No when i first bought my spree the aircleaner hose wasnt attached to the carb I could break 40 easy now with the aircleaner on i can hit like 32Trafficjamz wrote:SpreeMadness520 wrote:Why did my 86 spree run 10 mph faster without the aircleaner?
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- Trafficjamz
Re: 40 MPH Spree
SpreeMadness520 wrote:No when i first bought my spree the aircleaner hose wasnt attached to the carb I could break 40 easy now with the aircleaner on i can hit like 32Trafficjamz wrote:SpreeMadness520 wrote:Why did my 86 spree run 10 mph faster without the aircleaner?
Most sprees will not even run without the airbox.
If yours did 40 without it, it would be the first time in spree history.
- SpreeMadness520
Re: 40 MPH Spree
I will try it again tommorow i guess
Maybe even get film of it?
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- Trafficjamz
Re: 40 MPH Spree
Have you changed the jets in the carb?
If you run your spree with no airbox, you risk blowing it up from running too lean.
- spree-rider
Re: 40 MPH Spree
A spree at 40 mph??
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
- KillinSpree
- SpreeMadness520
Re: 40 MPH Spree
I doubt it the guy i bought it from wasnt the smartest in the world?? Yeah there is a good engine blowing possibility but ive got another spree engine and 300 bucks
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- Trafficjamz
Re: 40 MPH Spree
Do you have 2.5 tires?
The spreedometer is not very accurate.
GPS verified 40mph would be very impressive.
- SpreeMadness520
Re: 40 MPH Spree
Everything is stock tires and all, Idk how it was possible but i was flying at 40. Possibly the ridiculous power to weight ratio?Trafficjamz wrote:Do you have 2.5 tires?
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- bradthreee
Re: 40 MPH Spree
Im not calling you a liar, but its highly unlikely that your spree does 40mph. Even if you are a very small asian girl, it probably would top @ 35mph...
Do you need glasses?
Re: 40 MPH Spree
The stock speedo only reads 35 mph. How do you know it is doing 40? Oh and down hill don't count.SpreeMadness520 wrote:Everything is stock tires and all, Idk how it was possible but i was flying at 40. Possibly the ridiculous power to weight ratio?Trafficjamz wrote:Do you have 2.5 tires?
- SpreeMadness520
Re: 40 MPH Spree
I know its going 40 by the needle next to 4 0Bear45-70 wrote:The stock speedo only reads 35 mph. How do you know it is doing 40? Oh and down hill don't count.SpreeMadness520 wrote:Everything is stock tires and all, Idk how it was possible but i was flying at 40. Possibly the ridiculous power to weight ratio?Trafficjamz wrote:Do you have 2.5 tires?
http://i1224.photobucket.com/albums/ee3 ... 0BITCH.jpg
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- Trafficjamz
Re: 40 MPH Spree
Power/weight has more to do with acceleration than top speed.
You were probably going 35 tops. The spree speedometer is not very accurate with a 2.5 tire.
