Start button doesn't work but will start when short solenoid
keithhlars
Post by keithhlars »
When I hit the start button the headlight dims and nothing happens. If I short the solenoid terminals it starts. I was told that power for the solenoid comes from the brake light. So is there a swich somewhere that is engaged when the brake is on that might be bad? If so where is it? If not, what else could I check?
bc117
Re: Start button doesn't work but will start when short sole
Post by bc117 »
you shouldn't be using the E-start with the engine running, which is the only time your light should be on
1985 aero 50
ported
custom exhaust
ruckus vario
1K polini clutch springs
hopefully nh80 powered soon!
I was told that power for the solenoid comes from the brake light. So is there a switch somewhere that is engaged when the brake is on that might be bad? If so where is it? If not, what else could I check?
Here's marked up diagram of the starting system. You can see how the brake light circuit powers the 'high side' of the starter relay coil. If your brake light is lighting, it's usually enough, but you could check at the starter relay connector for +12v on the G/Y wire.
Could be starter relay contacts dirty/worn. Can you hear it click when the start switch & brake is energized? If so, given you get the starter to run with the contacts jumpered (.."If I short the solenoid terminals it starts...) check out the relay.
keithhlars
Okay I feel really dumb. I just realized from the last reply that you have to have the brake on when you press the start button.
No one here has ever forgotten this Honda-san Safety-Boy feature. At least, we can't get anyone to admit it... :)
amazing4
Post by amazing4 »
Im having the same problem but Ive got both brake switches shorted with jumpers and still missing 12v at relay...also, ive got a small harness with 3 female leads hanging by the oil tank with 1 green, 1 black, and 1 green/yellow stripe. Where does this go and could it be related to starting prob??
amazing4
Post by amazing4 »
Nevermind..I'm an idiot. Thank you.
CNI Dawg
Post by CNI Dawg »
Wheelman-111 wrote:Greetings:
LOL.....I forgot & did it just yesterday ! :D:D:D
61Aand Still Having Fun !
Keeping the Dream Alive ! :)
01 Elite 50SR
CMRA #77 MCE, '03 CBR600RR - Dark Horse Racing
