Page 1 of 2
rear tire kicking my butt.... I won!!!!!!
Posted: Thu Apr 07, 2011 6:51 pm
by KingJeff801
So I have tried locking the brake, stiing on so it doesn't move, adding a 2 foot piece of pipe to my socket wrench for extra leverage and the d*** thing won't budge
any secret tricks or am I doing something wrong.
Re: rear tire kicking my butt
Posted: Thu Apr 07, 2011 7:04 pm
by Trafficjamz
What are you trying to do?
Posted: Thu Apr 07, 2011 7:13 pm
by KingJeff801
soory wasn't real specific ,trying to get the rear rim off and I have concored some tough nuts but this takes the cake
Posted: Thu Apr 07, 2011 7:35 pm
by KingJeff801
I am about ready to get out the dremel and the precision surgical and cut this d*** thing off
Posted: Thu Apr 07, 2011 7:48 pm
by evilone
Do you have access to an impact gun?
Posted: Thu Apr 07, 2011 7:55 pm
by KingJeff801
evilone wrote:Do you have access to an impact gun?
I work at Home Depot and am thinking about buying one tomorrow! I have a bunch of 18v cordless ones but dont think they would work, so pneumatic power? this should do the trick?
Posted: Thu Apr 07, 2011 8:03 pm
I had a front axle nut kick my * once too. Dremeled off with cutting wheel in 2 sections and still had to chip it with a cold chisel. Japanese rust is made of stronger stuff.
by evilone
I use an air impact whenever i have a stubborn rear wheel nut. It seems the impact action is sometimes needed since the wheel held by the brakes can "flex". I've never used an electric impact so i can't compare it to an air impact.
Posted: Thu Apr 07, 2011 8:17 pm
by KingJeff801
evilone wrote:I use an air impact whenever i have a stubborn rear wheel nut. It seems the impact action is sometimes needed since the wheel held by the brakes can "flex". I've never used an electric impact so i can't compare it to an air impact.
I wouldn't even try with a cordless(i have the 1/4 " shank ones that have been known to shear off)...I will will buy a air impact tomorrow and if that doesn't go its dremel time.
Posted: Thu Apr 07, 2011 8:28 pm
by z50r-ghost
Don't dremel that nut, KJ!! (please). -that would hurt your poor scooter! Possibly even make it cry!
It's a definite you need an impact gun, but you also may need a little heat from a propane / mapp gas torch. Torches are cheap!
Heat it up a bit, then use the impact. If that gives u no love, use a chisel and a hammer to "peck" that nut off. All it needs is to break free with a chisel, then impact it off. Have u tried a breaker bar yet?
PM me your phone number; we can chat about your setup.
jon
Posted: Thu Apr 07, 2011 9:13 pm
by SPREEtown
pre soak w/ pb plaster?
Posted: Thu Apr 07, 2011 9:36 pm
by onna spree
Just had this problem 2 days ago, I ran a 3' pry bar through the wheel, under the motor, put box end wrench on the nut, put leg over the bar to hold wheel, and beat the#@!$%^$@!# out of it....broke it right loose!
Posted: Thu Apr 07, 2011 9:46 pm
by Trafficjamz
KingJeff801 wrote:evilone wrote:Do you have access to an impact gun?
I have a 14v snap on cordless impact. It spins that nut right off
Posted: Thu Apr 07, 2011 10:27 pm
by KingJeff801
Trafficjamz wrote:KingJeff801 wrote:evilone wrote:Do you have access to an impact gun?
Then I might just try my 18v makita!
Posted: Thu Apr 07, 2011 10:33 pm
by maddog
WoW !!! you guys make me look like a god, just put in for a heavy equipment mechanic, the job is mine cuz its inhouse
