working on a jetski vs scooter
aside from the obvious differences, how much different is it working on pwc's as opposed to the single cylinder scooters? Anyone made the transition? I may have the opportunity to start working on jetskis - we'll see.
1993 Elite - The Mad Max
Re: working on a jetski vs scooter
Water cooled 2 strokes run a lot cooler, hence the need for different oil. BUT other than that a 2 stroke is a 2 stroke.
I went the other way. I used to be big into Jet Ski's. They are not bad to work on.
Yes, but jetskis are 2t, 4t, turbo charged, super charged and those are just the factory models. The injection systems are far more advanced than any carb we have on our scoots. It is like opening a new car hood because there are just as many wires under that seat.Bear45-70 wrote:Water cooled 2 strokes run a lot cooler, hence the need for different oil. BUT other than that a 2 stroke is a 2 stroke.
Biggest piece of advice I can give you is to have it well ventilated. The engine compartment will trap fumes and can act like a bomb if ignited. Some shops in my area will not even service them because of this. If the seat is off, there is usually no damage to the ski. If the seat is locked in place, then you have a real bomb that will split the entire hull (hopefully).
It is easy to learn how to work on them. Getting used to it is another matter. Just put your scooter engine in a box and try working on it for a few hours to get a feel for it. Banged up elbows come with the job.
- spree-rider
Recently i've been looking for a Kawasaki x2 ski in my aera fo a small prject because that's a hobby i would like to get into
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
I just got this 1988 seadoo for $30. I'm charging the battery now and will see what all needs done. It was a little intimidating when i first removed seat and saw all the "stuff" but after looking at it more it's not bad at all. The guy hauled some stuff for another guy who gave him the seadoo as payment. The guy i got it from said "i just want my $30 in gas back".
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- SpreeMadness520
Quick question, Didnt that seem kinda sketchy to you? lol
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- spree-rider
the hull is worth easily $150
86 spree
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
Depends on your area, I couldn't give away a hull I had last summer. Those older skis are really easy, almost as simple as our scoots with the addition of another cylinder. These new ski's are the fancy ones. I don't know what is currently offered in the civic but there was a time when Honda's jet ski had a bigger engine than the civic (both displacement and HP).spree-rider wrote:the hull is worth easily $150
Nah, It quits running and seeing how it's a 2-stroke the owner doesn't know what to do to fix it, seeing how the brand new battery didn't get it running! So he trades it for services or sells it really cheap. Sounds like several of us forum members have aquired scooters this way, huh? And the guy i got it from was probably close to 60-65, full beard, and hobbled when he walked. It was a lawn ornament to him. I'll find out soon enough if it's worth getting it going.SpreeMadness520 wrote:Quick question, Didnt that seem kinda sketchy to you? lol
I'm sure the new fancy ones are a p.i.t.a. to work on compared to my 88. This is alot like our scooters once you start tinkering with it.eliteguy50 wrote:Those older skis are really easy, almost as simple as our scoots with the addition of another cylinder. These new ski's are the fancy ones.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
