Sprelite The Begining Of My Epic Build
- SpreeMadness520
Here are my plans,
50mm Taiwan bore with CHT gauge
Keli or Polini Performance Clutch (1500k)
Some Type Of Racing Variator
And 9 To 1 Gears.
Looking For A Throttle Cable For The Dio And Probably Brake Cable. Hit Me Up Thanks
And 9 To 1 Gears.
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- Trafficjamz
Re: Sprelite The Begining Of My Epic Build
The spree you rode had 9.1:1 gears
My elite had 8.4:1 gears
- fastplastic
mine with non worn out tranny parts is a wheelie machine..... look more towards 7.9 or 8.4s
- SpreeMadness520
I really liked the elites gearing so i will try to get 8.4s or any other good suggestionfastplastic wrote:mine with non worn out tranny parts is a wheelie machine..... look more towards 7.9 or 8.4s
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
Is 99mm off the left side of the elite engine mount correct?
- Elite engine mount
- Enginemounts001.jpg (29.79 KiB) Viewed 13250 times
Last edited by SpreeMadness520 on Fri Apr 08, 2011 6:46 pm, edited 1 time in total.
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
How much do I take off of the top part?
- Elite Engine Mount
- Enginemounts002.jpg (79.82 KiB) Viewed 13249 times
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- Trafficjamz
We measured the stock Elite E Mount. Then marked it on the Elite S mount.
You can do the same with the spree mount.
- SpreeMadness520
Ok I See That Doesnt Seem To Hard How Much Do I Take Off Of The Top Part With The Rubber Bumper?
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
Engine Off, Cutting The Elite Mount Monday
- Missing an engine.jpg (71.01 KiB) Viewed 13182 times
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
Still Need To Know How Much To Take Off Of The Stem W/Bumber
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- Trafficjamz
Enuff so the rubber bumper is in the middle of the hole on the frame.SpreeMadness520 wrote:Still Need To Know How Much To Take Off Of The Stem W/Bumber
- SpreeMadness520
Ok can I use a spree shock? I think the bolt I need is M10 140mm.Trafficjamz wrote:Enuff so the rubber bumper is in the middle of the hole on the frame.SpreeMadness520 wrote:Still Need To Know How Much To Take Off Of The Stem W/Bumber
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
Wow that cut is going to be real close to the arm
- more pics 002.jpg (142.06 KiB) Viewed 13157 times
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- SpreeMadness520
Cut the metal piece off of the spree mount
- more pics.jpg (136.43 KiB) Viewed 13143 times
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
