72cc looking to run 9.1 gears
- scottinscotty
Once again.. a little messing around with the 8.44 and changing some variator weights and still want more low end power...
is a 9.1 gear too low? can i damage my engine? will it rev to high? im pretty shure it's regulated with the stock cdi ... no?
72cc polini contesa kit
oko variator with 8.5 gram malossi weights
21mm Black Oko Carb & Ct Manifold
8.44 gear
malossi MHR exhaust
Dio zx trans conversion
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
Re: 72cc looking to run 9.1 gears
scottinscotty wrote: is a 9.1 gear too low? depends on the top speed you want
will it rev to high? depends on the cruising speed you want
im pretty shure it's regulated with the stock cdi ... no? No
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- scottinscotty
top speed no more than 60mph
cruising speed is no more than 50
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
- scottinscotty
its mostly stop and go around here
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
9:1 should do the job, i haven't personally used 9:1 but i will on my latest build using the polini 72. I'm looking at the same 60 mph top, cruising around 50 mph, and lots of stop light to stop light action.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- burnt_toast
running 9:1 with 74cc Ruima and love it. great for stop and go, and 45-55mph cruising
projects galore
- scottinscotty
i can't thank everyone enough for all the help, my scooter runs awesome and i can't wait to get my 9.1's...
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
- scottinscotty
well long story short... im back to running my 8.44's .. the 9.1's were a little to short for my setup.. it's crazy to think that the little 72' makes that much power? But i ride everyday and enjoy the highway crusing speeds of the 8.44's i'm runing the stock clutch springs, center spring, 8 gram weights and an oko variator, and she' really fly's !
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
Consider a ZX rear pulley if you need more low-end. Top speed should remain the same if you accurately shim the front pulley boss. See Tech Docs.
Did you get a wot run with the 9:1 gears? If so what speeds did you see?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- scottinscotty
i did get a wot run.. but my variator weight was a little off, and had a 1500 center spring in... , just gessing hit 54, or 55.. but rpm was upwards of 9000, now i'm rolling somewhere in around 60 or maybe better.. but rpm's are at a cool 7800 to 8000 and she pulls great!
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
I wonder if your variator maxed out with the 1500 center spring.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- fastplastic
My setup hits a Lil over 10600 and I gpsed 50.8
- scottinscotty
if i've learned anything... it's to change one thing at a time.. and focus on one thing at a time.. i'm not shure how fast i'm really going... but the needle will pin to the bottom of the speedometer.. and it' keeps pulling.. with the stock carb on and stock exhaust..
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
GPSscottinscotty wrote:if i've learned anything... it's to change one thing at a time.. and focus on one thing at a time.. i'm not shure how fast i'm really going... but the needle will pin to the bottom of the speedometer.. and it' keeps pulling.. with the stock carb on and stock exhaust..
