HELP me finish my elite!!!!
Posted: Mon Apr 11, 2011 7:18 pm
by thatguy80
Hey guys, you have always been super helpful when i needed some information. I could really use some help again!
The scooter in question is a 1989 elite e sb50p
So far i have put in a 48mm bbk and am working on breaking it in. I have the gears for it too but have yet to get them shaved down and install them. My plans were to do a little more in there while i was at it to try to squeeze a little more out of my scoot!
I have read alot on here about roller weights... i feel like i have a pretty good handle on what they are and their purpose. I figured my scooter has nearly 4k miles on it and they are pretty d*** near warn out. While i was installing the new gears i thought i would swap the old weights for some new ones... possibly ones that would help my top end. Also figured my belt is prolly pretty worn so better replace that too! I read that goin form a 15mm to a 17mm belt will also help.
So scooter gods please help me!!
heres what i need....
1) a link to a thread on how to do the gear swap, pulley mod/ roller weights
2) what kind of weights would be suitable for my application?
3) is the belt thing a good idea? if not what belt should i get???
Thanks in advance! if theres anything im missing please let me know!!!
Re: HELP me finish my elite!!!!
Posted: Mon Apr 11, 2011 7:59 pm
That Guy asserted:
And axted:
Really, you've installed the BBK and didn't have a look behind the belt cover, Dawg? If its original NQ/05 engine still hangs thereunder, your Roller Weight problems are
Solved!: They ain't none.
Pulley Mod can be read in Advanced Tech docs, and gear swaps likewise, though there are but two on the NQ/05 - SB/05 block.
A new belt and yes, a pulley mod to gear it taller are both a good idea.
Posted: Mon Apr 11, 2011 8:27 pm
by thatguy80
Really, you've installed the BBK and didn't have a look behind the belt cover, Dawg? If its original NQ/05 engine still hangs thereunder, your Roller Weight problems are Solved!: They ain't none.
Well i feel like an idiot... shortly after posting i did a little more snooping around and figured out that there really are none! haha
im new to scooters and have only had this thing for a couple weeks and am just learning new things as i go.
I also figured out that the stock belt is 10.4mm not 15... i understand that the pulley mod involves shaving off the face of the pulley... is this a route i should take??? or would just a wider belt help give me a little more? if so what size? how much larger should i go??
Thanks for all your help!!!!
Posted: Mon Apr 11, 2011 9:22 pm
Sorry my post sounded a little harsh. I didn't want you to feel stupid. Well, maybe a little fun at your expense...
Basically all this newfound torque and power now needs something to chew on. Taz's gears and perhaps a 2.75 or 3.00 rear tire if it'll fit are a good start.
Belt choices will be limited by the availability of suitable belts. Pinching the front pulleys a little closer together will increase the gearing a bit more. I'll leave the How of the pulley mod to those who've actually done it.
Posted: Mon Apr 11, 2011 9:34 pm
by thatguy80
haha wheelman dont worry!
Thanks for all of your help!! I appreciate it!
I guess i will get those gears shaved down, look into the pulley mod a little more, and search for a new belt, and possibly a new tire!!
If anyone out there has any links as to where i can find a new belt it would be much appreciated! and maybe a little help with the pulley mod! Thanks!
Posted: Mon Apr 11, 2011 10:46 pm
by Trafficjamz
thatguy80 wrote:haha wheelman dont worry!
Don't do the pulley mod
and the gears.
That will be too tall of a ratio.
Posted: Mon Apr 11, 2011 11:07 pm
by thatguy80
Don't do the pulley mod and the gears.
K thanks that makes sense... and it helps cuz thats one less thing i have to research! haha
anyone got any thoughts on the tire size??? should i go with a 2.75 or 3?? and how much will this do/help??
any good ideas on where i can get a belt and the new tires? ive checked ebay and can get tires but any place cheaper??
Thanks again!
Posted: Tue Apr 12, 2011 7:05 pm
by red spree
thatguy80 wrote:Don't do the pulley mod and the gears.
Thanks again!
These fit good for sure...
http://www.motorcycle-superstore.com/5/ ... -Tire.aspx
Posted: Tue Apr 12, 2011 11:43 pm
by thatguy80
These are 3.5's if im not mistaken... will these fit on the elite without any clearance problems???
The price is great! Just wonderin what size i should go with... 2.75,3, or 3.5??? please let me know what you guys think!!
Should i get two or is the front one fine staying stock? Thanks!
Posted: Wed Apr 13, 2011 8:17 am
by red spree
I pretty sure its only 2.84in less then 3 more then 2.75. I had these exact tires on my stock spree I just sold so I know they will fit... Id buy two.
Posted: Wed Apr 13, 2011 10:12 pm
by thatguy80
Thanks red spree! I actually just bought 2! 35 bucks shipped!!! not too bad i thought!
Am i going to need to buy new tubes for them?
Oh and ive been meaning to ask someone about the taz gears! I have an elite e so i need to machine them down but i dont know which one and even where to go to get it done! Can someone PLEASE help me with this?
Is there anyone out there that would let me ship it to them and have it done for a good price? PLEASE!!!
Posted: Thu Apr 14, 2011 10:15 pm
by thatguy80
Is there anyone here that will let me ship my gear to them and have it milled down to fit my elite e transmision??? Please help! has anyone done this?
and the tires?? new tubes or are the old ones ok??
Thanks guys you r very very helpful!
Posted: Thu Apr 14, 2011 10:30 pm
Tubes can get damaged in tire removal/reinstallation process. If they hold air now and you don't pinch them taking off the old tires, they should be fine. A few Forumistas have the mills and talent to take the shaft down to E size. Hopefully someone will offer. Sorry my Rock-and-Stick tool kit won't do.
Posted: Thu Apr 14, 2011 10:54 pm
by thatguy80
Thanks wheelman!!
Where do you think i should post to see if anyone would help me with the gears?? is there anyone that knows a forum member that could do this for me so i can pm them?
Posted: Thu Apr 14, 2011 11:17 pm
by eliteguy50
thatguy80 wrote:Thanks wheelman!!
Your local machine shop can do it. They will ask for the size and tolerance. I just gave them my case and said I wanted a slip fit.
