How to start an SE50 motor, not mounted to the frame
I have an SE50 motor in my basement that I'm "rebuilding". I'd like to get it running before I try to mount it in the spree, but the wiring has me a little confused. How can I wire up the coil, and the electric starter and bystarter? Thanks for any help!
Re: How to start an SE50 motor, not mounted to the frame
Connection wise: The service manual is available on this site.
Execution wise: Get a spare wire harness, cut off the connectors, and wire up the needed circuits. That way all the correct connectors are present to tie in to the engine and electrical accessories (coil, cdi, stator, bystarter, start button, starter relay, kill switch, +12v Main switch)
- spree-rider
+ ground!
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
