I need a picture!
Thugorp
I need a picture!
Post by Thugorp »
could someone please post a pic of a mounted carborator? I can't tell which red hose goes were!
Things I've learned on this forum:
  • How to change my scooter's fuse
  • How to change my scooter's spark plug
  • Why my scooter's oil keeps going away :-%
  • how to take apart and put back together my scooter's body pannels
fightingplankton
Re: I need a picture!
Post by fightingplankton »
really easy.
the hose coming out of the bottom of the petcock goes to the lower of the 2 nipples on the carb.
the hose coming out of the side of the petcock attaches to the top most nipple of the carb.
'86 spree
'86 aero50
'83 aero80
the hose coming out of the bottom of the petcock goes to the lower of the 2 nipples on the carb. the hose coming out of the side of the petcock attaches to the top most nipple of the carb.
What model scooter does Thugorp have? Petcock vacuum line runs to the intake for some. And some inject oil into the carb. on the upper fitting.
For the petcock, the line on the bottom goes to the vacuum tap. Honda often used a smaller ID tube for petcock vacuum than the fuel, so a visual inspection of the tube end may cover it. Cut off a 1/2" or so if needed.
Link to petcock diagram
Photo guide for 88-93 SA50 carb lines
Thugorp
Post by Thugorp »
Oh right sorry I have an spree 86maybe?
Ok - Spree has an angled fuel inlet at the left side of photo like the carb in this pic (it's actually an SB50 carb)
For the petcock vacuum line, the intake at the right side of photo is a Spree. Vacuum line goes on the topmost fitting. Oil line is the lower fitting.
