Hi!
I'm new here, and need some help!
I've just bought a Honda Dj1-r.
Needs a restoration.
I found a few technical documentation here,
but i need the original specs of the weight roller.
Now, it 16x13, 8.5g.
Anyone knows the original "mass"?
Thank you!
Dj1-r weight roller
Re: Dj1-r weight roller
16x13 10grams here for the US model and that's with either the 11to1 or 10to1 gears. If yours has the goshi dj1rr style exhaust with the chrome tip then you will need the 9gram rollers. If your using a aftermarket variator then your going to have to get a tunning kit as you may have to mix match rollers to get it tuned right.
Thanks for the help!
I have the original exhaust and variator.
So 9 gramms should be ok?
- dj1r1.jpg (108.85 KiB) Viewed 3624 times
- KingJeff801
I miss my 87, definately the coolest bike Honda has ever made
especially if you swap in a DIO
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Yeah 9gram rollers should be fine.
Thank you!
