circlip destroys cylinder and freezes piston... help
SPREEtown
Post by SPREEtown »
long story short: circlip came loose and wedged itself b/n the piston and the cylinder wall. top end is * but stuck together. i can get some purchase on the clip but i cant free it. any ideas?
1986 Spree SE:
  • pulley mod
    '85 head
    SB50 intake, reeds, carb
    UNI filter
    44mm bbk
    3x10 conti zipps
    next:
    taz gears, sa50 clutch w/ 2k springs
SPREEtown
Re: circlip destroys cylinder and freezes piston... help
Post by SPREEtown »
ok nvm. i got the d*** thing out, but i am worried about my brand new crank bearings. i dont remember what it felt like to turn the crank over by hand. it certainly doesnt turn freely but it isnt rough and there is no play. is this in the realm of normal?
1986 Spree SE:
  • pulley mod
    '85 head
    UNI filter
    44mm bbk
    3x10 conti zipps
    next:
bakaracer
Post by bakaracer »
Yes the mag/stator and seals will put a little resistance on it. Look to see if there is metal shavings on the crank and in the case. You might have to rinse the case out if there is.
dun rite
Post by dun rite »
I feel for you.. Had that happen recently myself. Personally felt safer for me to split the case and clean everything, didn't trust just using a flashlight and mirrors to see all.
Have you removed jug yet? if not it probably won't turn freely. good luck
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
