Main jet size Honda Melody NT50
Hi,
What is the standard size mainjet in the carburator please?
Regards
Torben
Regards
Torben
- fastplastic
Re: Main jet size Honda Melody NT50
no clue on what the nt50 is but honda usally sticks to 65 for some sprees and 68 for elites and some elites on there 50cc
Just got the Honda and can make it run smooth after a carburator cleaning by using the choker 100 pct... Guess that indicates I need to fit a larger main jet - like a size 65?fastplastic wrote:no clue on what the nt50 is but honda usally sticks to 65 for some sprees and 68 for elites and some elites on there 50cc
- fastplastic
what size is in it right now
Ahh, sorry forgot to tell you - It's a size 52fastplastic wrote:what size is in it right now
- fastplastic
i guess up jet but do plug chops to make sure its correct
Ok will try a size 65 to start with.fastplastic wrote:i guess up jet but do plug chops to make sure its correct
If your scooter is all stock why should you have to up the main jet. could be still something clogged in carburetor or filter not allowing enough flow?
The Carburetor and filter has been cleaned, but I dont know the history of the scooter as to type of cylinder, piston etc. All i know is that it does not run correctly and I dont know what the stock/standard size of the main jet is...dun rite wrote:If your scooter is all stock why should you have to up the main jet. could be still something clogged in carburetor or filter not allowing enough flow?
torbenras wrote:The Carburetor and filter has been cleaned, but I dont know the history of the scooter as to type of cylinder, piston etc. All i know is that it does not run correctly and I dont know what the stock/standard size of the main jet is...dun rite wrote:If your scooter is all stock why should you have to up the main jet. could be still something clogged in carburetor or filter not allowing enough flow?
Fitted at size 68 and the scooter is now running as it should. I'll upload some pictures for you to see how the Danish version looks like.
- April 2011 015.jpg (34.79 KiB) Viewed 9233 times
- April 2011 013.jpg (30.15 KiB) Viewed 9233 times
- April 2011 012.jpg (30.01 KiB) Viewed 9233 times
Just two more
- April 2011 014.jpg (31.08 KiB) Viewed 9234 times
- April 2011 016.jpg (28.86 KiB) Viewed 9234 times
- bradmeehan
That looks so cool!
1986 Spree
1986 Spree (Big Bore)
1985 Aero 50
1985 Aero 80
1988 Elite 50 (SB50)
1985 "OrangeJuice" (Sold)
1985 Aero 50
1985 Aero 80
- spree-rider
want to sell your rear plastics? All of them? i will pay a more then fair price. Mr. Eve smile look alike.
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
If I did, I would miss them myselfspree-rider wrote:want to sell your rear plastics? All of them? i will pay a more then fair price. Mr. Eve smile look alike.
Are they that speciel?
- spree-rider
oh yes. almost any spree owner in amarica loves them.
86 spree
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
