Dio gear case oil?
SpreeMadness520
Dio gear case oil?
Post by SpreeMadness520 »
What kind? Lmao :peace:
130cc Stroker
1984 Porsche 944
1965 Vespa
odinxxix
Re: Dio gear case oil?
Post by odinxxix »
3 oz of 10W-30 your choice
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
devenex
Post by devenex »
This never ends well...
1986 Spree w/ '87 SE50 motor
burnt_toast
Post by burnt_toast »
valvoline 10w40 full synthetic
works great for heat transfer in hopped up motors, imo
projects galore :nerd:
tru72
Post by tru72 »
GL5 80/90 wt
fill till it over flows from fill hole..
tru72 wrote:GL5 80/90 wt
80/90 wt oil in your trans :crazy: That is too thick.
Motor oil 10/30 :thumbwink:
tru72
Post by tru72 »
lol i tried to use auto matic trans fluid as well just to see hehe. It works pretty nice , I figured that it is was made for meshing of gears, high pressure and temp. Only problem i have seen is that the oil is way thinner and it seems to make any really small leak become a bigger one hehe.
I have never used engine oil in my gear case.. maybe its because i never used engine oil in a rear end of car either..LOL but i did put sawdust in one once...
to each his own...
Noooo! Keep it organic, Man! Scrape up and save used KY Jelly and siphon it in there, mixed with bacon drippings.
Anyone sez otherwise should have his head examined by a stonecutter, then be deported to Yemen.
KingJeff801
Post by KingJeff801 »
Wheelman-111 wrote:Greetings:
:worship: :worship: :worship: :worship: :worship: :worship: :worship: :worship:
Good Call..............
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
kylebo
Post by kylebo »
what do you think of the old straight weight oil like 30 sae why would that not be better than a multiple weight oil. Thats what Im going to put in on my next change. I put the closest oil in the shop in my gear boxes 80w, snowmobile chain case oil, dirt bike case oil, atf would be the best you could use for the gears and bearings but in my opinion You will need both new seals and gasket If atf is used that stuff will leak threw a beer bottle.
01 dio, polini 72cc, 8.4 gears, 28oko, ruima crank, PG short, ported intake, 42.3 rolls
2nd build
86 aero
10-1 secondary gears form a dio.
arisol 46mm
pg short
carb? not yet
tru72 wrote:lol i tried to use auto matic trans fluid as well just to see hehe.
to each his own...
kylebo wrote:You will need both new seals and gasket If atf is used that stuff will leak threw a beer bottle.
That is what the saw dust is for :naughty:
I think coffee beans and hot water should go in the trans cover.
Honda Dio Brew :lol:
bc117
Post by bc117 »
FYI 80w90 is sulfur based and corrosive to certain metals, that in itself could be the sole reason that honda decided not to use it in their scoots
1985 aero 50
ported
custom exhaust
ruckus vario
1K polini clutch springs
hopefully nh80 powered soon!
