Coil Problems
Coil Problems
I have a 1985 Spree that went about 30 mph when I first got it. After about a week, it seemed like it was going slower and didn't have much acceleration. I took the carb apart and cleaned it. When I put it back together, the moped went even slower, leading me to believe that I have the air/fuel screw set wrong. When I pull the plug, though, it is tan, so I think that the screw is set right (I followed the manual.) The spark seemed weak, so I tested the coil. Everything was good except for the primary (0.5 ohm when the limit is 0.3) would this be enough to effect performance (the moped gets up to about 22 mph, sometimes not even that, and starts to sputter like its getting too much gas, but the plug always looks fine)
- Pygmaelion
- Goped
- Pygmaelion
- Goped
