performance question.
ok so im on my way to work this morning when after going over a speed hump i lose power/speed went from 25 mph to 10-15 said o well and continued on for a block or two shut it off ,restart and than ran better. now could it be the 27 year old rubber band being too hard/dry i removed cover and cluch bell looks llike it got hot.has some bluing on it.belt is glossy kinda hard.went to auto zone got temp belt put it on and pow 22-24 mph flat ground spreedo.is this ok performance?and it seems to vibrate more at top speed is it the auto belt perhaps?and finally can a faulty bystarter lean out an engine and kill it? this 84 spree is my way around so its gotta run any and all advice/help would be awesome!!!
thanks
scott
thanks
scott
Re: performance question.
What belt did you get?woodman wrote:ok so im on my way to work this morning when after going over a speed hump i lose power/speed went from 25 mph to 10-15 said o well and continued on for a block or two shut it off ,restart and than ran better. now could it be the 27 year old rubber band being too hard/dry i removed cover and cluch bell looks llike it got hot.has some bluing on it.belt is glossy kinda hard.went to auto zone got temp belt put it on and pow 22-24 mph flat ground spreedo.is this ok performance?and it seems to vibrate more at top speed is it the auto belt perhaps?and finally can a faulty bystarter lean out an engine and kill it? this 84 spree is my way around so its gotta run any and all advice/help would be awesome!!!
thanks
scott
With the Spree you start out in High gear, hence the clutch gets hot.
No, the bystarter can only enrichen the mixture as long as it is installed. If removed it can cause a lean condition.
next a bystarter stupid electric parts expensive lol thats life!
thanks again well off to work
scott
The stock belt is 628x11.4x30 mm. The number I have is Dunlop DSL AX-24
thank you sir. the stupid belt i bought worked for 25 miles but i got to work and back
i just hope it is a belt issue and not a thrashed cylinder time to go to honda.
- spree-rider
i have a gates 7240 and it works very well. alot cheeper at $9
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
thanx spree-rider ill check it out. i know one thing for shure duralast 13250 no good.
bongs r better
scott
bongs r better
scott
- spree-rider
BONGS are always better. but i do think that a hukah is much better.
86 spree
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
well i guess that is true but only with a few good buds....er friends and dont forget the doritos
- spree-rider
Puff cheetos, a 4 loko, and a couple rockstars and im set.oh, And the homies.
good bud? I got the best. i got them PINE CONS . . . of heavenly swwet, delicous, mouth watering, DANK
86 spree
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
ahhhhhhh if only to live in the northwest heck the northeast would do im really REALLY getting tired of the south.
thanks
scot
got my belt and woo hoo 25+ uphill 30-33 on flat 35-40 downhill and a whole lot smoother/quieter time to ride hope it dont rain today! happy scootin to all who read this.
scott
scott
