jetting?
blaster716
jetting?
Post by blaster716 »
I just learned that the exhaust on my elite e is restricted , if I remove the restriction what size jet do I use.
89 Elite-e
2010 Yamaha Stratoliner
2007Suzuki Z250
2004 Yamaha Blaster
2004 Polaris Trailblazer 250
2004 Polaris Sportsman 90
1992 Suzuki Samurai
Re: jetting?
According to Deepinnaharta Honda's Fiche (save this to look up anything you want...), the Mains are 65 and 68 for the P and "Regular" models, respectively. It is reasonable to assume that de-restricting your P model will result in the need for a 68. Remember Honda-san was jetting to the edge of very lean for EPA reasons, so it might be better to go a little bigger, particularly if you open up the airbox or get a tricky pipe.
KingJeff801
Re: jetting?
Post by KingJeff801 »
I have had good success with a 90 jet
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
Re: jetting?
KJ, this is an SB50. It speaks Spree-ish. Maybe a 90 with a big-bore kit and a pod filter, but for sure it's too big for a Stock-ish de-restricted SB.
KingJeff801
Re: jetting?
Wheelman-111 wrote:Greetings:
:oops: Didn't have the contacts in....I thought is was an S
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Re: jetting?
You need a big screen like I have so those letters aren't so small. :shock: :lol:
blaster716
Re: jetting?
So Im assuming that a 68 jet would do the job?
89 Elite-e
2007Suzuki Z250
2004 Yamaha Blaster
1992 Suzuki Samurai
