94 elite SR, vibrates at the bottom when you throttle
Posted: Sun May 15, 2011 6:20 pm
by walks0nwater
recently purchased 2 of these bikes and one of them starts to make a weird vibration when you throttle up passed about 25mph(usually but mostly its just a random speed) not sure how to explain it exactly. these bikes have been sitting for about 5 years pretty much and they are just starting to break into being used again. any suggestions on what it could be?
Re: 94 elite SR, vibrates at the bottom when you throttle
Posted: Sun May 15, 2011 7:02 pm
If the engine is 4 stroking from being too rich it will do this.
Posted: Sun May 15, 2011 7:12 pm
by evilone
Check the center stand, it might be vibrating on frame.
Posted: Sun May 15, 2011 7:27 pm
by walks0nwater
Bear45-70 wrote:If the engine is 4 stroking from being too rich it will do this.
not sure what you mean by this. can you elaborate please? and will check the center stand hopefully thats all it is.
Posted: Sun May 15, 2011 7:30 pm
walks0nwater wrote:Bear45-70 wrote:If the engine is 4 stroking from being too rich it will do this.
A 2 stroke fires every time the piston comes up in the bore. When a 2 stroke starts 4 stroking it only fires every other time the piston comes up in the bore. Makes the engine run rough.
Posted: Sun May 15, 2011 7:45 pm
by walks0nwater
so whats the solution to this problem?
Posted: Sun May 15, 2011 7:54 pm
walks0nwater wrote:so whats the solution to this problem?
Check you carb for cleanliness and proper setup. I would check the center stand before I tore into the carb
Posted: Sun May 15, 2011 7:58 pm
by walks0nwater
yes my engine is 4 stroking, i found a useful video on youtube that shows the difference between the sound of normal and 4 stroking. idk how to tune the carb really..i did clean out though when i first got the bikes thats how i got them running in the first place
Posted: Sun May 15, 2011 8:05 pm
walks0nwater wrote:yes my engine is 4 stroking, i found a useful video on youtube that shows the difference between the sound of normal and 4 stroking. idk how to tune the carb really..i did clean out though when i first got the bikes thats how i got them running in the first place
Download the service manual in the Owners and Service Manual section of the forum. Then look in Wikispreedia here on the forum. Look in the technical section of Wiki for carb cleaning and needle and seat resurfacing.
