Dies on full throttle?
sublok
Post by sublok »
85 nq50, the person i got it off of put in a throttle stop, said that it spree lost all power when full throttle - and dies
Any ideas?
MySpree
Post by MySpree »
iots boggomg, to much air or not enough gas.
sublok
yea
Post by sublok »
thats what i though. Though i cant really check cause there is a d#$% throttle stop on there.. I have to get my tool out today and find out how to take it out.
MySpree
Post by MySpree »
ok what do you mean throttle stop?
sublok
Post by sublok »
the throttle only moves about maybe 10-30 degrees when turned.
-aL-
Post by -aL- »
so the guy u bought it from put a throttle stop on it bcuz it died when it was full throttle... he didnt really fix the problem now did he...
Ridin' Dirty on one of my 1989 Honda Elite E's
darat
Post by darat »
mine dose the same but it pops and bogs out. i think i have a air leak..
MySpree
Post by MySpree »
mine did that, but then i put a new bystarter o ring it and it was all good
sublok
Post by sublok »
so i took it apart took that throttle stop out. they just put a piece o plastic in the throttle spring to keep it from going all the way. I found that the top of the air intake has been chopped up. there are multiple holes drilled in int and a large chunck missing. I am going to change out the top and hopefull that will fix the issue. I think its just getting too much air...
MySpree
Post by MySpree »
to much air will do that...
sublok
Post by sublok »
so i covered all the holes. and still the same issue. i wonder if there is an issue with carb - sending too much gas. Its great a lower speeds just when you give it full throttle it just boggs down and dies out..
You're running lean if it's doing that. You've either got an air leak in the intake, something's loose, or your air filter's screwed up.
sublok
Post by sublok »
i am not sure why they cut all those holes in the air filter cover. But i used elec tape to cover all of them except a little sopt for some air to come in. I drain all the oil and bleed the lines. Blew it out with compressed air, added new oil, let it run at idle for about 10 mins. I justed finished test running it. Its not choking out now at full throttle.
thanks everyone. I will check later to make sue once it has cooled down, that everything is still running smooth..
How much smoke should be comming out, a cloud or just tiny ammounts?
Clouds at first (choked or been off the road awhile,) then nearly nothing. Make sure you're using 2-stroke injector (red) oil. Green stuff fouls plugs and smokes more.
Contact Greg at uspmale@yahoo.com for a new cover, or just cover up the holes like you're doing.
MySpree
Post by MySpree »
yea... never put marine oil in...
