Bolt On Spree-Dio swap Shock Mount SLOPE DISTANCE TESTER....
- richdavison34
The pics below show a "test kit" that I have manufactured for spree-rider.
The theory is to hold the plate against the bottom of your frame in the area that the new shock needs to mount. You will then screw in the bolts until they touch the bottom of the pressed frame halves. The nuts are self locking, but it may help to throw a little lock tight on the threads to seal them in place. (Or you could use a file or something to score the threads as they exit the nut as a marking point if you didn't want to leave the bolts in place). Once that's done, the tester would be mailed back to me so I could evaluate the distances/slope.
I think this is just about the best way to get this right without actually having a spree frame on hand to look at. This tester was made using some generic measurements provided to me by spree-rider.
What do you guys think?
- IMG_3564.jpg (95.25 KiB) Viewed 10343 times
- IMG_3563.jpg (109.37 KiB) Viewed 10343 times
- IMG_3561.jpg (80.92 KiB) Viewed 10343 times
1984 Honda Aero 50.
Carb Swap. Cone filter.
1984 Honda Aero 50.
- richdavison34
Re: Bolt On Spree-Dio swap Shock Mount SLOPE DISTANCE TESTER
With bolts installed.
- IMG_3567.jpg (91.55 KiB) Viewed 10342 times
- IMG_3566.jpg (95.42 KiB) Viewed 10342 times
1984 Honda Aero 50.
1984 Honda Aero 50.
- richdavison34
Like this.....
- Test.jpg (254.49 KiB) Viewed 10339 times
1984 Honda Aero 50.
1984 Honda Aero 50.
- Petrock's 1984 Spree
If you want it to fit perfect against the bottom of the frame the thing to do would be to get some clay and press if against the bottom of the pressed frame so it captured the contours of it and you can then take the dimensions off of the clay
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
- Trafficjamz
I think that trying to make a part for a scooter that you do not have will be very difficult.richdavison34 wrote:
Also, I think that this shock mount project is kinda a waste of time. Let me explain.
Doing a "spree/dio swap" is actually pretty easy if you own tools. The more tools you own, the easier it is.
The tools needed for an easy conversion are:
1. Screwdrivers
2 .metric sockets and wrenches
3. wire strippers/cutters
4. Drill and metal drill bits
5. sawzall or metal hacksaw
6. chopsaw or horizontal bandsaw
7. welder (optional)
most people have 1 and 2 (we will call them catagory A people)
some even have 1-4 (category B)
but very few have 5-7 (Category C)
Now ask yourself , who would want to buy a bolt on spree-dio shock mount?
Category A people cant use it .....they don't own a drill.
Category B people don't need it because they do own a drill, and could just drill a hole though the frame, stick a bolt through and mount a shock. Plus category B people could never finish th project because the have no tools to cut metal.
Category C People won't buy it because they have all the necessary tools to do it themselves.
You clearly have talent, I would hate to see it wasted on this.
If you want to make a spree/dio conversion part....
- richdavison34
Thanks for the feeback traffic.
Back when I first posted asking if anyone needed anything welded or fabricated, I got this responce.....
It actually looks like several people have had a lot of trouble and headache trying to install these mounts.
A good thing to keep in mind is that a lot of these fab jobs that are being attempted end up in a poor and more importantly, unsafe state.
If you are attemping to do a motor swap, and you do not possess Numbers: 1,2,3, and 4 on your tools list, then you will be dead in the water to begin with.
I think the person looking for a bolt on shock mount will be someone who only wants to drill 4 holes and install 4 bolts that will be provided to them, and what wants the confidence of knowing that they are riding on something that isn't going to break. Also, if they ever want to go back to the original engine, there won't be multiple hours of griding out welds.
Install time for my mount would be approx 15 mins. Done deal.
Moving onto the motor mount you brought up. I am willing to make any part that any member needs done. If you have an idea of how that engine mount needs to look..Please let me know. I will do everything I can to make that happen. Are there some threads that deal with this...possibly some pics?
Thanks again for your feedback, that's exactly what I'm looking for. If it is indeed a waste of time, I want to know about it. If there are new parts that people are interested in, I want to know about it.
From what I can see in the threads no-one has dilled a hole straight through the frame and installed a bolt. It loos like the mounting position has to be below the fame, or your rear tire will not have proper clearance with the rear of the frame.I'm probably not the only person interested in a bolt-on shock mount for Spree motor swaps, if its possible.
1984 Honda Aero 50.
1984 Honda Aero 50.
- fightingplankton
maybe this is just me...
i've always preferred the round headlights from the bikes across the pond. i have been contemplating fiberglassing a new cover and sticking one in...but the problem is, idk how i'd mount it.
now, this is just me...im positive no one else on here is going to go to all that effort just to have a round headlight, so...probably not something really marketable.
i remember reading dthat someone wanted a grab bar for their elite... thats probably something that you could have a wider market w/.
well, thats my last 2 cents, have to wait til payday to stop being broke.
'86 spree
'86 aero50
'83 aero80
'86 aero50
'83 aero80
- richdavison34
Thanks for the feedback plankton!
Send me a pic of how the headlight bracket needs to look.
I'm not concerned with mass production, or mass profits. I just want to fabricate.im positive no one else on here is going to go to all that effort just to have a round headlight, so...probably not something really marketable
Pic....? Example.....? Like I said, I'm willing to make anything for any member.i remember reading dthat someone wanted a grab bar for their elite... thats probably something that you could have a wider market w/.
1984 Honda Aero 50.
1984 Honda Aero 50.
- fightingplankton
viewtopic.php?f=1&t=19149&p=163480&hili ... te#p163480
edit: the owner of the grab bar pictured above went on to say he wished he could get one for his aero in another thread.
and since you own an aero, this may be a perfect job for you.
'86 spree
'86 aero50
'83 aero80
'86 aero50
'83 aero80
- Trafficjamz
richdavison34 wrote:Thanks for the feeback traffic.
Here is a Spree/dio shock mount done with just a bolt and some washers. A small tack weld was done just to hold it in place.
A longer gy6 scooter shock (or an elite e shock) was used to make up the small difference of the mount location.
- SpreeMadness520
The whole kit thing seems kinda sketchy to me
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- fastplastic
I WANT A SIDE STAND JUST LIKE THE ONE FIGHTING P HAS!!!!!!!!!!!
- richdavison34
Understandable, noone here has acutually seen a finished product from me, and I don't expect anyone to have full confidence in my design until it has been proven. Until the design is proven effective, I certainly don't plan on selling this to anyone.The whole kit thing seems kinda sketchy to me
All I mean by "kit" is that the mount would come with the bolts you need to mount it.
Thanks for the pic traffic. Looks like that would work for it's intended purpose, but it still requires welding. No offence to the person who made that, but I wouldn't trust the structural integrity of a handfull of washers and a tack weld.Here is a Spree/dio shock mount done with just a bolt and some washers. A small tack weld was done just to hold it in place.
I'm definitely not out to convince you guys until this product is done and proven. I'm not going to be charging an arm and a leg for this either. I'm in it to help you guys out and have some fun fabbing some stuff, not to rob you guys.
I will begin the design process for a side stand this weekend.I WANT A SIDE STAND JUST LIKE THE ONE FIGHTING P HAS!!!!!!!!!!!
1984 Honda Aero 50.
1984 Honda Aero 50.
I think he drilled through the frame and then just tac'd it so it wouldn't move. I don't trust putting the shock mount outside of the boxed frame unless it is reinforced. Which is why I uses 14" of 1/8" steel plate to reinforce mine and spread the force of the shock out over a bigger square area. But that's probably over kill. Whatever you plan on making, use strong stuff. I love 1/8" steel plate and grade 8 bolts. And with the welds you've shown I'd trust my neck on something you've made. Just find a way to mount it real solid.
Drilling through the frame just seems a bit sketchy to me, that frame is super thin stuff
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
- richdavison34
For sure!! I was actually thinking 3/16'' plate, and the bolts would definitely be grade 8.Which is why I uses 14" of 1/8" steel plate to reinforce mine and spread the force of the shock out over a bigger square area. But that's probably over kill. Whatever you plan on making, use strong stuff. I love 1/8" steel plate and grade 8 bolts.
The mount would be bolted to the frame halves (the pinched area where the top and bottom frame halves are pressed together), but would also be snugged up against the bottom of the frame as well. This would distribute the force across the strongest part of the frame.
Thanks man!!And with the welds you've shown I'd trust my neck on something you've made.
1984 Honda Aero 50.
1984 Honda Aero 50.
