Page 1 of 2
New Guy here!!
Posted: Mon May 23, 2011 1:18 am
by ScootStick1
Hello everybody,
My names Randy I live in Mid Missouri and I just picked up a '94 Elite that is pretty rough and needs some work, I have been scouring the boards for info but I have quite a few questions which I will get into later...
Will have pics of this train wreck for you guys tomorrow, Thanks in advance for all the info
Re: New Guy here!!
Posted: Mon May 23, 2011 1:38 am
by Trafficjamz
welcome
Here is a pic of my latest train wreck
Re: New Guy here!!
Posted: Mon May 23, 2011 1:41 am
by dun rite
welcome scootstik 1. Hope your wrecks not as bad as Trafficjamz
Re: New Guy here!!
Posted: Mon May 23, 2011 11:32 am
That wacky Thomas the Tank Engine won't mess with the Jet Engine again anytime soon. You must have some young kids, 'Jamz! Wheel-Boy is all into Thomas too.
Welcome, Randy. Hope the Jopliin Tornado didn't mess up your neck o' the woods too badly. Congrats on the '94. It's a Good model with which to start. We're full of information around here. Full o' somethin', anyway...
Re: New Guy here!!
Posted: Mon May 23, 2011 12:28 pm
by eliteguy50
Welcome.
Re: New Guy here!!
Posted: Mon May 23, 2011 12:42 pm
by richdavison34
Welcome to the forums.
There are a lot of very smart guys on here, I'm sure your Elite will be good to go soon.
Re: New Guy here!!
Posted: Mon May 23, 2011 1:54 pm
by ScootStick1
Thanks for the welcome party gents, I'm about 4 hours from Joplin the weather was sooo crazy here yesterday.
Anywho, I'll post pics of the scooter when I get home. I just picked it up yesterday it needs a little work but it's going to be fun. They put a filter similar to a UNI filter on it and left the carb alone so she is running weird.
I'm very interested in doing some mods to this thing to get it in a comfortable 50ish mph cruising speed. Ive looked at the polini bbk and a few other items but if anyone has the best way for me to reach my goal I'd be all ears
Re: New Guy here!!
Posted: Tue May 24, 2011 3:47 pm
by fastplastic
78cc nick bore with 8.4 gears will make you very happy and give you more then your looking for for about 300 bucks (bore, carb kit, and gears)
Re: New Guy here!!
Posted: Tue May 24, 2011 6:42 pm
Fast-Plastic has given very good advice, if you axt me. DayWOT's Nikasil 49mm/78cc is among the most durable, if not highest-performing bore kits I've tried. Believe me if it was easy to destroy, I would have done it!
I had mine going about 60MPH with 8.4s, which is about as tall as that setup should go. Mine had a pipe, a CT manifold and a series of different carbs - all about the same performance. An
Arreche-for-Honda carb in the 19 or 21mm size can be bolted straight up to the stock manifold. (The link is for example only. Scooter-Center.com once had them cheaper in Germany, but I couldn't find one today. Google "Amal Arreche Vision". You might want to add the 26mm V8 Pipe from JiangWayne to your list to reach 60 Top, easy 50-55 cruise. Still under $400 for the carb, pipe, bore kit, and gears. Reliablility should be as good as stock.
Re: New Guy here!!
Posted: Wed May 25, 2011 1:12 am
by ScootStick1
Re: New Guy here!!
Posted: Wed May 25, 2011 8:07 am
by fastplastic
You dont need CDI box and your carb is way to big for a d.d. if you want to run that bbk go for it but you will need to switch your gears out......
Re: New Guy here!!
Posted: Wed May 25, 2011 11:36 am
by ScootStick1
Thanks for the help man, Sounds like I really need to look into gears.. any specific brand I should look into?
Seperate question-- The previous owner put a foam filter on it similar to a UNI Filter and now it seems like its getting too much air and it cuts out pretty bad. Jet the carb up? What size jet should I be running I believe everything else is all factory
Re: New Guy here!!
Posted: Wed May 25, 2011 11:41 am
by eliteguy50
ScootStick1 wrote:Thanks for the help man, Sounds like I really need to look into gears.. any specific brand I should look into?
No specific brand, half of them probably come out of the same factory in Taiwan and then just get a different brand at distribution. 9.8:1 will give you bullet proof 45mph and the best acceleration.
Try an 88 or 90 main jet and check your plug from there.
Re: New Guy here!!
Posted: Wed May 25, 2011 11:56 am
by Trafficjamz
eliteguy50 wrote: 9.8:1 will give you bullet proof 45mph and the best acceleration.
9.8 gears are too short
9.1 or 8.4 gear would be better
9.8's would make your engine rev too high
I would get the prodigy variator instead of the Keli. I comes with a ramp plate and more rollers for the same amount of $$
Get your gears from the same seller and save on shipping too.
http://cgi.ebay.com/ebaymotors/Racing-v ... ccessories
http://cgi.ebay.com/ebaymotors/17x41-sp ... ccessories
Re: New Guy here!!
Posted: Sat May 28, 2011 12:19 am
by ScootStick1
Thanks for the insight... Unfortunately, I'm about 750 miles from my scooter for a week as my Grandmother passed away in Alabama. I really wish I had my scooter down here so I could tear up some of these beautiful backroads
