Spree Intake is Here 21mm carb
tazland001
Post by tazland001 »
The spree intakes came in today. Wow. They really add some serious acceleration to my spree with the 48mm kit. Takes off very strong. It was raining and I have to dial it in a bit. Will post pics tomorow. I am running a 21mm carb. hehe. Wait til you see this. :naughty:
Taz
Re: Spree Intake is Here 21mm carb
What is the freight gonna be on this?
z50r-ghost
Post by z50r-ghost »
I dont have a spree.... But I can't wait to see them!! -taz's parts are some top notch stuff!!
J
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
z50r-ghost
Do you have any pics of your spree intake mani and your spree performance pipe, Taz?
I cannot wait to see what you came up with for the pipe...
It's about time someone manufactured a pipe for the spree!
j
...my life story
1990HONDANS50F
Petrock's 1984 Spree
Post by Petrock's 1984 Spree »
With the 48bbk, 21mm carb, CT Mani, and exhaust pipe i would bet the spree could go a solid 45 all day long.
Couple in the clutch mod and bigger tire and the wimpy spree engine just turned into a relative beast! :thumbsup:
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
Petrock's 1984 Spree wrote:With the 48bbk, 21mm carb, CT Mani, and exhaust pipe i would bet the spree could go a solid 45 all day long.
Not without the gears it won't.
dyehardfan
Post by dyehardfan »
Ok, so once I find someone to machine my head, I am considering the next step of the resto-mod to be Taz' Carb/Intake kit.
Taz Carb Kit
Taz Carb Kit
http://cgi.ebay.com/ebaymotors/Honda-Sp ... _500wt_698
First question, and this is for everyone, how does this compare to the CT Mani that I see talked about all over the board? Could this be adapted to a 6 reed setup?
Second question, for Taz, is the only available throttle cable color blue? Much rather have a black one...nothing vinyl dye wouldn't fix I guess.
1987 Honda Spree:
*Complete Engine Resto/Mod
*Engine Torn Down
*Replaced Crank/Rod/Bearings
*Taz 48mm BBK & Gear
*Taz Carb/Intake
*Custom Exhaust
*Porting and Tuning
*Upgrade Rear Shock
*Upgrade Brakes
*Paint - Hunter Green & Saddle Brown Seat
It IS the CT manifold with an adapter to fit the Spree. Yes you can use the 6 petal reeds, but you will not see any performance increase from them.
dyehardfan
Bear45-70 wrote:It IS the CT manifold with an adapter to fit the Spree. Yes you can use the 6 petal reeds, but you will not see any performance increase from them.
Sweet on the IS part, but what about what you had said here:
"The 6 petal compared to 4 petal reeds will improve the bottom end and mid range throttle response and performance. The old multiple carb adage applies here, "a lot of little holes is better than a couple of big holes." The top end will not be hurt and depending on the area of the reed openings can be improved."
viewtopic.php?f=4&t=14843&hilit=CT+Manifold+group
1987 Honda Spree:
*Engine Torn Down
*Taz Carb/Intake
*Custom Exhaust
*Porting and Tuning
*Upgrade Rear Shock
*Upgrade Brakes
The 6 petal will help the bottom end but without a variator the Spree isn't going to be able to really utilize it. I will be saving my money when this set up goes on my Spree. Increased compression and finding some higher RPM clutch springs will help more than going with the 6 petal reeds.
dyehardfan
Bear45-70 wrote:The 6 petal will help the bottom end but without a variator the Spree isn't going to be able to really utilize it. I will be saving my money when this set up goes on my Spree. Increased compression and finding some higher RPM clutch springs will help more than going with the 6 petal reeds.
Ok, thanks. I'll roll with the original until I get to point of being in the "what the heck can I do next" stage.
Insetad of going off topic, I'd like to know more about these higher RPM clutch springs if you have time for a PM sometime soon.
1987 Honda Spree:
*Engine Torn Down
*Taz Carb/Intake
*Custom Exhaust
*Porting and Tuning
*Upgrade Rear Shock
*Upgrade Brakes
dyehardfan
Taz, can you tell us a little more about the reeds you are using in this kit? Are they metal, fiberglass, carbon-fiber?
1987 Honda Spree:
*Engine Torn Down
*Taz Carb/Intake
*Custom Exhaust
*Porting and Tuning
*Upgrade Rear Shock
*Upgrade Brakes
If its just the regular CT mani they come with fiberglass reeds
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
dyehardfan
Petrock's 1984 Spree wrote:If its just the regular CT mani they come with fiberglass reeds
Cool, good to know. I'm really thinking about going with this thing. Hopefully Taz will chime in with a full breakdown on the kit when he gets a moment.
1987 Honda Spree:
*Engine Torn Down
*Taz Carb/Intake
*Custom Exhaust
*Porting and Tuning
*Upgrade Rear Shock
*Upgrade Brakes
If this doesn't tell you what you need to know, Nothing will.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... _500wt_956
