Fill in by-starter hole
Posted: Tue May 24, 2011 9:08 pm
by toad772
Well my by starter is completely screwed It has no wires on it and it is busted all to * so I want to remove it and fill in the hole. So how do you think I should do it?
Re: Fill in by-starter hole
Posted: Tue May 24, 2011 9:19 pm
by richdavison34
Buying a new one may be your safest...and ultimately cheapest....alternative. :imo:
Posted: Tue May 24, 2011 9:25 pm
by odinxxix
if you fill in the hole just how is it going to run while its warming up? think id find a new or used one. or you could get a manual choke like bear has.
Posted: Tue May 24, 2011 9:42 pm
by toad772
odinxxix wrote:if you fill in the hole just how is it going to run while its warming up? think id find a new or used one. or you could get a manual choke like bear has.
Has ran fine with it just stuck extended all the time.
Posted: Tue May 24, 2011 10:00 pm
by KillinSpree
Brand new on ebay for $35 or pm *mopedmark* and he'll hook you up. Super fast shipping too :thumbwink:
Posted: Tue May 24, 2011 10:13 pm
by toad772
The scooter is only gonna be used in the woods but I will check ebay
Posted: Tue May 24, 2011 10:38 pm
My manual choke system only works on the Aero 80 (1983 thru 1985) and a couple of earlier model scooters that had the heat control vacuum bystarter. Oh and bystarter is one word, not two.
Posted: Sat May 28, 2011 3:55 pm
by toad772
Well I filled both ends in. Haven't tested it yet because I am too lazy to put the air box back together and bolt the carb back on.
Posted: Tue May 31, 2011 11:59 am
by toad772
Runs perfect without the Bystarter on there and isn't all that hard to start(5 kicks)
Posted: Tue May 31, 2011 12:11 pm
by dun rite
Hello: what did you fill the holes with?
Posted: Tue May 31, 2011 12:45 pm
by toad772
dun rite wrote:Hello: what did you fill the holes with?
The bottom end I drove a nail into it a bit then cut it off flush with my scroll saw and the top part were the by starter goes I put the needle in and filled the hole with rtv silicone gasket maker(Both holes could be unplugged if I ever wanted to buy a new bystarter)
Posted: Tue May 31, 2011 1:54 pm
Well nice job, you have RUINED the carb because now another bystarter will not work on it. :jack:
Posted: Tue May 31, 2011 2:06 pm
Well it's off to the Home Depot to pick up a box of 16 sinkers........I'll fix that d*** bystarter.......then I'm gonna ride out to the woods and irritate a bear with my pea-shooter......I'm pretty sure that will do it...........
Posted: Tue May 31, 2011 2:21 pm
by toad772
Well I could unplug it not gonna though because it works fine without a bystarter.
