look what i picked up for $20 !! just needs new piston rings
andythespreeowner
Post by andythespreeowner »
do you think this is a good deal for $20...
all it needs is new piston rings to run...
only 1,330 miles
wood10214
Re: look what i picked up for $20 !! just needs new piston r
Post by wood10214 »
Wish I can find one like that :thumbwink:
I don't mod my scooters to go Fast, just want to keep it running!
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
andythespreeowner
:peace:
The un ripped seat is worth at least $50
Nice find :thumbwink:
reynoldston
Post by reynoldston »
I picked one up like that and have keeping it just for parts but the only problim is that they are just so well built I just never need parts. The only thing I have used so far off it is the tires. Have you got paper work so you can register it? Looks like some plastic and lights are missing which maybe you can find parts off E-Bay. What did they do run it out of oil? Looks like a nice find and hope you the best of luck with it.
andythespreeowner
no i dont have papers or anything and i just checked compression and its at 120 so its not the rings so now im not sure what it is.... any ideas :sad:
devenex
Post by devenex »
Does it have spark?
1986 Spree w/ '87 SE50 motor
andythespreeowner
yes it has spark and i just checked the carb and it is very clean :confused:
but still the motor wont even "pop"
not even trying to start :sad:
Wow - good deal!
-- Reeds?
I've had a scooter which had sucked a disintegrated air filter into the reeds, blocking them open.Previous owner pulled the bad airfilter out of the airbox, but likely never figured out why it wouldn't run.
-- Spark timing?
Some members have had the flywheel loose its keyed alignment with the crank get off - sheared or missing key.
reynoldston
Spark, compression, fuel, and timeing and it will run. I have seen some good suggestions so far. Also the spree needs a complete hooked up air cleaner to run.
devenex
Post by devenex »
Also make sure exhaust isn't plugged.
reynoldston
You might want to check what you need to do to register it in Connecticut before you spend much money on it. If you can't register it all it will be good for is a parts bike. In NY you would need paper work but as I understand some states you don't. This was the problim about the parts bike I have which I bought from a lawn sale.
evilone
Post by evilone »
devenex wrote:Also make sure exhaust isn't plugged.
I didn't even think of that...my first Spree had mud in the end of muffler and did nothing, i cleaned muffler out and it started right up.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
toad772
Post by toad772 »
reynoldston wrote:You might want to check what you need to do to register it in Connecticut before you spend much money on it. If you can't register it all it will be good for is a parts bike. In NY you would need paper work but as I understand some states you don't. This was the problim about the parts bike I have which I bought from a lawn sale.
Well you could drive it unregistered or just use it off road.
PS3 it only does everything.
andythespreeowner
i checked and it doesn't need to be registered in Connecticut
i think and it must be the carb because it doesnt seem like its getting gas.... but the spark plug has gas on it when i take it out so im not sure. i think im going to have to keep trying stuff.
thanks guys :smile:
