Best decesion of my life
SpreeMadness520
Post by SpreeMadness520 »
100% worth doing
130cc Stroker
1984 Porsche 944
1965 Vespa
evilone
Re: Best decesion of my life
Post by evilone »
What, the inline fuel filter?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Here's what I see:
  • It's got a manual petcock downstream of the OEM vacuum petcock
  • There is a 'T' in the feed to the carb with a line with a 2nd petcock to the oil tank - Scoot's been converted to pre-mix..
  • I think it wise the oil tank sensor wires are disconnected. Switch contacts are above the float level and are not arc-proof
  • Picture date says '2007' and it was a sunny 11th of January. :)
SpreeMadness520
Dont mind the date haha, I converted the oil tank to a reserve gas tank. Help A LOT
130cc Stroker
1984 Porsche 944
1965 Vespa
If you are running with plastics on - what did you do to get access to the petcocks?
SpreeMadness520
Im no where near ready to put plastics on, Ill find out when I get there :2thumbs:
130cc Stroker
1984 Porsche 944
1965 Vespa
Good workmanship, Here's one idea:
Slotted driver dowel - in metal, plastic, wood - whatever. Triangular slot cut into petcock knob. Triangular key mounted into driver to center. Could use a spring roll pin or put a knob on over the shaft for the external drive side.
Or just cut a hole in the plastic big enough of the valve knob to stick thru and tie strap the nipples to the plastic to hold it there. Of course lengthening the hosed to reach properly. Like I did for the ball valve for my manual bystarter on my Aero 80.
I never thought of that. How high do you think my * will fly up if I ever let the fuel level in the SR oil tank turn on that "Low Oil" lamp? :nervous:
Wheelman-111 wrote:Greetings:
With you * on fire, you won't really give a d*** how high you get! Image
Why do you need access to those petcocks?
Aren't they just there for when you work on the carb.
BTW you missed a zip tie on the T . :smile:
Trafficjamz wrote:Why do you need access to those petcocks?
Anytime you shut the scooter off and walk away for any length of time you should shut off the fuel. That's what the auto petcock does. Otherwise it can be dangerous. Image
tru72
Post by tru72 »
you might wake up the next day with a motor full of gas, it will continue to push gas thru the float needle and flood the motor.
SpreeMadness520
TrafficJamz-The top of the T was so d*** tight to fit on it doesn't need a yellow zip tie :2thumbs:
130cc Stroker
1984 Porsche 944
1965 Vespa
Quoth SpreeMadness:
I had the same tight fit and the same thought. Funny how it came apart anyway, leaving me stranded in a pool of gasoline while on the way to the Dentist's. Put a clamp on there anyway, if you axt me... Hot-cold-Hot-cold wiggle-jiggle and it comes apart eventually.
Now that you mention it, my Low Oil light did come on that day, without a Scootery Conflagration. I guess I cheated death that day.
