1984 spree carb setting
I'm sure it's already somewhere on the forum, but what is the good screws settings on a 1984 honda spree carb?
Re: 1984 spree carb setting
Ya..... I had to dig to find it too !lamie2012 wrote:I'm sure it's already somewhere on the forum, but what is the good screws settings on a 1984 honda spree carb?
here's some 'quick click' links to help you out & save you some time
Wikispreedia located here:
http://hondaspree.net/wiki/index.php5?title=Main_Page
Technical Section:
http://hondaspree.net/wiki/index.php5?t ... al_Section
Carburetor Air/Fuel Adjustments - Spree:
http://hondaspree.net/wiki/index.php5?t ... ts_-_Spree
Carb adjustment screws pic here: (won't display pic in the standard [ img].jpg[ /img] format for some reason)
http://hondaspree.net/wiki/images/1/15/ ... Screws.jpg
Screw in air screw until it lightly seats then turn it
'84-'85 1 7/8th turns out
'86 1 1/2 turns out
'87 1 3/8ths turns out
Reset the idle speed with the throttle stop screw
Turn the air screw in or out to find the highest idle speed
Reset the idle speed with the throttle stop screw. Idle spec is 1800 rpm.
Make sure that the engine does not miss or run erratically. If necessary repeat steps 2 through 4
61Aand Still Having Fun !
Keeping the Dream Alive !
01 Elite 50SR
CMRA #77 MCE, '03 CBR600RR - Dark Horse Racing
01 Elite 50SR
