the spree is finally running!!!!!!!!!!!!!!!!!!!!!!!!! <3 <3
andythespreeowner
Post by andythespreeowner »
:woot:
finially got the spree running and it runs great!!!!!
turns out the problem was as simple as when starting it with a drill from the flywheel
it had to be turned counter clock wise not clock wise!!!
thank you so much for everyones help
:coolcruise: :coolcruise: :coolcruise: :coolcruise: :coolcruise: :coolcruise: :coolcruise:
dun rite
Re: the spree is finally running!!!!!!!!!!!!!!!!!!!!!!!!! <3
Post by dun rite »
:D congrats.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
Mystic
Post by Mystic »
Awesome, glad to hear it andy. I was hoping you wouldnt throw in the grease rag before you got your first bit of oil on it :D Keep us post on your progress and some pics :D
