1986 Spree restoration
adios1344
Post by adios1344 »
(I have posted random junk around here the past few days, so I decided instead of spamming boards and reiterating myself in different topics, I will keep this and the Spree Chopper topics active. I'd delete the others if I knew how)
However, after messing with more wiring, and the multimeter I noticed there was no power going past my relay. It went to the relay, but no power to the switch :( So, I am going to guess that is bad. I decided against getting another harness after realizing how stupid I was. Also, it helps I know an electrician that had absolutely no trouble finding the problem. :D
Also, I noticed I have a turn signal as a tail light, hence why it didn't change brightness.
I will hopefully have these problems sorted out tomorrow.
I am calling this 'restoration' because I am essentially properly redoing my poor little beaten and abused Spree.
onna spree
Re: 1986 Spree restoration
Post by onna spree »
Keep the faith fellow "Hoosier," last Nov. I knew nothing about these critters, i have since restored 5 Spree's, 1 Aero, and am finishing up a "92 Elite " with Taz bbk (free plug cuz he sells good stuff) Read and learn, there is a wealth of info here. :peace:
adios1344
Post by adios1344 »
Turns out it wasn't a relay but a flasher? Um now really lost. Can't find any 3 pin flasher (or relay for that matter) on the wiring diagram
adios1344
Post by adios1344 »
What is this thing?
Whatever it is it's not working. Not getting any charge out of it :(
bradmeehan
Post by bradmeehan »
Those are salted cashews
1986 Spree
1986 Spree (Big Bore)
1985 Aero 50
1985 Aero 80
1988 Elite 50 (SB50)
1985 "OrangeJuice" (Sold)
wood10214
Post by wood10214 »
bradmeehan wrote:Those are salted cashews
with sea salt
I don't mod my scooters to go Fast, just want to keep it running!
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
devenex
Post by devenex »
I'd estimate there is approximately 2lbs 2oz of them.
1986 Spree w/ '87 SE50 motor
It you do not know what it is how the * did you determine that it is not working? :jack:
with sea salt
devenex wrote:I'd estimate there is approximately 2lbs 2oz of them.
"WHOLE" cashews,.....Quality
adios1344
Post by adios1344 »
Bear45-70 wrote:It you do not know what it is how the * did you determine that it is not working? :jack:
My dad is an electrician, he knows whats going on. But I was told its a relay, then a flasher, and now nobody knows.
adios1344
Post by adios1344 »
Actually, Deluxe Whole Cashews.
wood10214
Post by wood10214 »
your electrician or your dad, should just see where the wire connect to.
I guess it has only 3/4 of box full only.
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
adios1344
Post by adios1344 »
We can not find this mysterious part on the wiring diagram
wood10214
Post by wood10214 »
turn signal relay
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
devenex
Post by devenex »
