I bought a 2001 people 50 2 stroke about a month ago. While riding to work at 50+ mph my engine died on me. Thought I might have blown head gasket, so I ordered a new gasket set and piston set from scooter assasins on ebay. Today I started to take her apart to be ready when the parts come in. Once I was able to get to the engine, I noticed that the jug and head said AIRSAL on them:
I am assuming that the PO installed a big bore kit. Once I got it apart, this is what I saw on the piston:
The first thing I noticed on the piston, is that there is only one ring. Seems kind of strange. i also noticed the burned out pinhole, and the one ring that there is, is now "welded" to the piston at the pinhole. I measured the piston across the bottom end and it measured 48mm. I believe that is the right place to measure it. The stock piston is 39mm. A huge difference!
I had the Taz kit on my Spree, and had to put a little extra oil in each tank of gas because the pump on the spree did not add enough for the extra displacement. Am i assuming correctly that i should have been doing the same thing here? What should I do to replace this, as well as make sure that it does not happen again? You guys have been the best so far with your advice. Although I am no longer a spree owner (should have kept it), i appreciate your valuable input. Thanks a million in advance.
Todd
