new break in way?
badasspree
new break in way?
Post by badasspree »
i am rebuilding my top end from an old engine, and i need to know, how should i break it in? should it be easy or hard? normal? check this article out: http://www.mototuneusa.com/break_in_secrets.htm
also, every time i open up a busted engine, one of the circlips has came lose and 'scored the *' out of everything. has this happened to you before? please help
darat
Post by darat »
lol yes it has i didnt have one of my clips in all the way i did a half * job on it thats y..
myhonda
Post by myhonda »
yup thats y my spree isent running right now.
badasspree
should the clip be covering up both of the holes on the side of the piston? -- the access holes to get the clip out
jbarb
Post by jbarb »
Is that the clip that holds the piston pin in place?
myhonda
Post by myhonda »
yes
Re: new break in way?
badasspree wrote:i am rebuilding my top end from an old engine, and i need to know, how should i break it in? should it be easy or hard? normal? check this article out: http://www.mototuneusa.com/break_in_secrets.htm
The article is biased to 4 stroke water cooled bikes, not sure it's applicable.
Personally, I'd take a couple of hours and run the thing around at about 1/2 to 3/4 throttle for about 30-50 miles or so, varying the speed. Note that this would take planning with a Spree, since at 25 MPH or so it will take you 2 solid hours of riding to do this.
Admin, Hondaspree.net
darat
Post by darat »
vt told me to run half throttle for one tank of gas.. i couldnt wait i got it running and i had to give it full but not for long..
MySpree
Post by MySpree »
cuz u blew the clinder!!!
darat
Post by darat »
no i didnt blow it up adam did..
MySpree
Post by MySpree »
eather way it was blown
uspmale
new break in way?
Post by uspmale »
cir-clips should be installed with opening at 12:00.
You may loose them in the cylinder if not installed correctly.
Good luck, greg
badasspree
thanks greg
