89 elite e clutch options
Jimmy l
Post by Jimmy l »
Hey guys, I recently picked up an 89 elite e and thanks to this board I got it up and running. I've still got couple issues to address and one is the clutch. It was not disengaging at all when I got it which cause the bike to bog miserably from a stop. So I pulled the clutch apart and bent the hooks on the springs a bit and that helped but it's still not right.
So, what options do I have for it? Obviously OEM new or used but is there anything aftermarket? Maybe a clutch from another model that will work? Like a GY6 clutch or something. I'm not really looking for any huge performance upgrades just cheap, available and "works" but I don't mind cutting the cover if I need to. Thanks in advance.
spewya
Re: 89 elite e clutch options
Post by spewya »
a spree clutch will work
spree parts for sale
still learning alot ..thanks to all on this fourm
if you have a good spree jug ..pm me if you want to sell it
ZMUD
Post by ZMUD »
The Clutch springs from 88-93 were junk. put a set from a 94-01 and you'll be fine. My friend just had the same issue!
94 elite 50s
66cc bbk
118jet/Pre-Mix32:1
1"uni-filter,Keli 9g
1k center,8.44 gears,ZX Trans
V8 Pipe,IRC MB38 80/90 tires
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
1" Uni-Filter,8:44gears
The spring tension is only one factor in cluch Disengagement. The othe is crud/corrosion at the pivot points. The clutch comes apart all the way, usually with E-Clips retaining the pivoting shoes. Knock those off, carefully, and inspect the pivots and any place where friction may be preventing prompt return. Clean and lube sparingly so your grease doesn't shower the entire assembly and the clutch you have may be made to work just fine. If not, used Spree/Elite "E" clutches should be affordable and easy to find here or on fEeBaY.
spewya
Post by spewya »
replace those rubber clutch dampers ..if you take the clutch apart you will see what i mean
they look like black rubber fruit loops
