The manual calls for two bolts, the inspection/Fill and the drain.
I don't seem to be able to get any tool to fit that bolt, I can't even reach it.
Is it required to take apart the tranny cover?
Thanks!
CH80 Elite Transmission Flush
Frank_1175
Re: CH80 Elite Transmission Flush
It is tight but I manage to get a thin walled 1/4 drive socket in there, if need be grind down the socket sides a bit extra, good luck.
Frank_1175
I got it out, it is a tight fit. I used my regular socket and the good old hammer.
Thanks,
Thanks,
