We talkin about gaskets?! Gaskets man!
Sorry for the bad Iverson reference. But what do you all do when you need a gasket that is no longer available? I need the head gasket and cylinder cover gasket for my 86 Elite. Just wondering what to do...
Chicago Ben
Re: We talkin about gaskets?! Gaskets man!
we talkin' bout practice!
From what I have seen lurking around the forums here is most of the guys trace and cut their own with gasket paper but you should still be able to order gaskets for that spree. check bikebandit.com or collegebikeshop.com
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
There is a conversion software that Bear had referenced in one of his posts that enables you to find what other models a honda part was used for. That might be the first place to start. Otherwise, I found that Yamaha used a very similar cylinder gasket on the yamahopper to my 83 Aero 50.
