i need more top speed on my aero 1984
mtully27
Post by mtully27 »
setting my 1984 aero right now i have 3 big spring for my clutch 1 white and bleu polini and 1 yellow malossi, also 2 set of 3 spring for my clutch 1 set white and one other yellow polini.
i put the the malossi big spring and the yellow set it good for quick start but high speed not good what the best for a highest speed
my clutch is a polini speed clutch 3g for race, malossi multivar wiith 7.5 grams rollers (also have 9gr)
did i have to put lower torque spring and lighter rollers weight ??
thanks because now it more a wheelies bike than an everyday use bike that get me to work faster)
(rolling on a malossi 70cc 47.5mm phbg 19mm carb 105jet)
nb50m 1984
bbk malossi fonte 70cc 47.0mm
nh80 reed and intake
variator malossi multivar mhr
7.5 roller
cdi unit
RMS clutch bell
exhaust doppler s3r
booster doppler
air filter doppler
shock absorber doppler racing
michelin 3.00
Re: i need more top speed on my aero 1984
Bonjour:
En depit des chevaux vapeurs robuste, I'll me semble qu'I'll te manque que le bon rapport d'engrenages pour realiser la vitesse de pointe que le moteur permettrait en potentiel.
Malheureusement, les pinions pour le bloc AB07 n'existent plus, si en fait ils existaient jadis.
Tu peux jouer aved des rouleurs 8 ou 8.5 grammes et verifie si la sangle realise sa pleine excursion sur les poulies. Marque la face avec ine plume Magic Marker pour voir.
martynkim
Post by martynkim »
Whoa Dude, c'est lourd.
