NEED IDEAS FOR A CHEAP, FAST BIKE
jlynn433
Post by jlynn433 »
Heres a pic of my bike. Its a 2000 Honda Elite S. Engine code AF16E. I was looking at some polini corsa kits, ruima ministroker kits and so on and so forth, but im looking at 800 dollars with that. I just recently got in to the scooter tuning scene and all i did was turn the smaller screw on the carb (not the idle or drain) in all the way which actually made it run a lot better, removed the restriction from the muffler and variator, and drilled out some of the baffles in the exhaust to make it flow a bit better (keep in mind it has 3k miles). I just need info on where to go for parts, what parts to get, and how to make my bike run really fast on a tight budget. she revs out at around 38-40 mph.
'00 Honda Elite S.....................'06 Yamaha Zuma
-80cc Taiwanese BBK...............-Taiwan pwr pkg
-Malossi Vari
-6.9:1 Primary gears
-High Energy Ignition Coil
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
kingkamehameha
Re: NEED IDEAS FOR A CHEAP, FAST BIKE
Post by kingkamehameha »
Cheap and fast is not reliable and reliable and fast is not cheap
GN Racer
Post by GN Racer »
An old adage...
Speed costs money.
How fast do you want to go?..... :coolcruise:
Geoff
'85 Aero 50 w/Dio 66cc
'87 Elite 50 w/Dio 72cc
'87 Spree -SOLD!
Puch Magnum
Yamaha Razz POS -Soon to be Dio powered!
jlynn433
Post by jlynn433 »
GN Racer wrote:An old adage...
Speed costs money.
it goes around 40 right now. i dont want an insane 120mph+ bike or anything of that caliber, but somewhere around 60 would be nice. i was thinking some new primary gears and a final drive at 9:1 or 7:1 on 72ccs.... i just got into all this and need some ideas
-Malossi Vari
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
sprite2011
Post by sprite2011 »
A nice gearing would help you out if you want to go beyond 40 mph without your motor scream to death. It's more of tuning than throwing thing on it to make it go fast. I would rake baby steps for now until you figured out 2 cycle motor.
dun rite
Post by dun rite »
jlynn433 wrote: all i did was turn the smaller screw on the carb (not the idle or drain) in all the way which actually made it run a lot better, removed the restriction from the muffler and variator, and drilled out some of the baffles in the exhaust to make it flow a bit better
You need to do a plug chop with a new plug. http://hondaspree.net/wiki/index.php5?t ... Plug_Chops
If you had to turn the adj. screw all the way in to make it run better than there is a possibility you have a vacuum leak , or could be caused by drilling out the exhaust restriction and the baffles but not rejetting the carb.
You are running with an air filter?
Hate to see that pretty scooter get hurt.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
jlynn433
Post by jlynn433 »
id hate to see her get hurt too shes my baby lol... i always ran it with the stock airbox and i did the carb adjustment before i drilled the baffles, so that cant be the culprit.... can you walk me through how to check the vacuum system?
-Malossi Vari
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
dun rite
Post by dun rite »
vacuum leak would be a bad gasket or seal in the intake system. you can use a flammable spray or unlit propane torch, with the motor running you spray around the intake gaskets. crankcase area seals, if the engine revs up at any spot than that gasket, seal, etc. is allowing air into the fuel delivery system.
arreche air filter
v8 pipe
stock gears
jlynn433
Post by jlynn433 »
And if i had a bad seal/vacuum leak would i fix it with just some gasket paper and rtv?
-Malossi Vari
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
PimpinSpree
Post by PimpinSpree »
Big bore kit, gears and a variator are the biggest speed makers. Should cost about 300. You could spend more on other stuff if you wanted to
jlynn433
Post by jlynn433 »
PimpinSpree wrote:Big bore kit, gears and a variator are the biggest speed makers. Should cost about 300. You could spend more on other stuff if you wanted to
What parts should i buy for the variator? I was looking at polini 7.7g weights but im not sure of exactly what parts to get for the variator system
-Malossi Vari
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
PimpinSpree
go to ebay and search "dio variator" People prefer the italian made stuff, but i seriously doubt its worth the price difference of the chinese stuff
Pierce ramsay
Post by Pierce ramsay »
I have a spare rumia vari. Very light and engine revs well! I think I bout for around $55 shipped more than willing to let go for $45 or reasonable offer also have spare poli vari. Doesn't say poli like the rumia says but still great and light wieght same price ... Pm me
jlynn433
Post by jlynn433 »
dun rite wrote:vacuum leak would be a bad gasket or seal in the intake system. you can use a flammable spray or unlit propane torch, with the motor running you spray around the intake gaskets. crankcase area seals, if the engine revs up at any spot than that gasket, seal, etc. is allowing air into the fuel delivery system.
I just got around to checking the vacuum system. this one seems to be the culprit. its the gasket on the bottom of the manifold where it meets the reeds
this is the torn/cracked gasket. would hi-temp gasket seal fix it? i have something made by permatex
2011-07-16 23.35.56.jpg (91.69 KiB) Viewed 8835 times
-Malossi Vari
-Carbon Fiber Reeds
-Chrome CT Mani
-28mm OKO Carb
-Uni Pod Filter
-PG Long pipe
PimpinSpree
Definitely will make your motor run poorly
