dio swap
KruZer
dio swap
Post by KruZer »
how much does it usually cost to do a dio swap on a spree, and do it right?
-LONG LIVE THE STIG!!!!!!-
SpreeMadness520
Re: dio swap
Post by SpreeMadness520 »
You need the dio, Engine mount, shock bolt, and some welding. I can weld so I didnt have to pay labor costs. Total price is going to vary
130cc Stroker
1984 Porsche 944
1965 Vespa
veedubh20
Re: dio swap
Post by veedubh20 »
Price may vary the dio moto , depend. Who built the motor.
Some dio Will Need repair like New crank, bearing and seal. Big bore kit.. Some other parts will have wear and tear..
Honda stock crank, bearing and. Seals can go long time running than Taiwan crank, bearing and seals, this is true! Over 10,000miles..
PimpinSpree
Re: dio swap
Post by PimpinSpree »
expect to pay 200-300 for the motor. Then you still need an exhaust, carb, rear brake cable, a way to mount the motor, and a way to mount the shock. Probably need a new kick stand
main cost is the motor, unless you plan on doing a bunch of mods, then who knows what your gonna spend
KruZer
Re: dio swap
Post by KruZer »
does an elite motor work just as well, or does it have to be a true NF16, or whatever it is?
veedubh20
Re: dio swap
Post by veedubh20 »
Af16 from 94-01 Honda elite sr50-sa50p. Or oversea Honda. motor from japan. $$$$
