I thought I would up date this a bit, I swapped the float from my elite which is compatible but not the valve from 94-01, the sa50 88-93 is the same not that it helps me any. it seemed to run a tiny bit better but still cut out on the rub board that is my road. sooo while waiting for a valve and float to come in for the spree i decided to do a little experimentation. I have been running without an exhaust gasket so i took an extra one i had for the elite and cut a chunk out of it and bent it back round and staggered the layers so that the cut section would be spaced out evenly so as to prevent any leaks. took her out and she only bogs on deep holes so I am thinking a large enough jar creates a leak around the exhaust at the moment of combustion causing me to lose some compression till I even out. before i had a gasket i couldnt jump up and down now i can without it bogging. ALSO I cross referenced the float valves and the same part number was used in my 83 c70 so I took it out and put that in the spree also, a tiny improvement but still the same. I put the spree valve in the c70 and it runs without a problem. I am willing to bet that at impact the exhaust opens a fraction at the head releasing some of my atomized fuel before it can properly combust. For future reference I have copied a list of most honda models that use the 16155-882-005 float needle, might be good to put in the wiki wheelman
also could the melted plastic in these pictures be a symptom of my exhaust leak?
This Honda 16155-883-005 VALVE, FLOAT is also used on these models and components:
1978 ATC70 A CARBURETOR
1979 ATC110 A CARBURETOR 79-83
1979 ATC70 A CARBURETOR
1980 ATC110 A CARBURETOR 79-83
1980 ATC70 A CARBURETOR
1981 ATC110 A CARBURETOR 79-83
1981 ATC70 A CARBURETOR
1982 ATC110 A CARBURETOR 79-83
1982 ATC70 A CARBURETOR
1983 ATC110 A CARBURETOR 79-83
1983 ATC70 A CARBURETOR
1984 ATC110 A CARBURETOR 84-85
1984 ATC125M A CARBURETOR
1984 ATC70 A CARBURETOR
1985 ATC110 A CARBURETOR 84-85
1985 ATC125M A CARBURETOR
1985 ATC70 A CARBURETOR
1985 TRX125 A CARBURETOR
1978 CT70 A CARBURETOR 78-79
1978 CT90 A CARBURETOR 78-79
1978 NC50 A CARBURETOR (2)
1979 CT70 A CARBURETOR 78-79
1979 CT90 A CARBURETOR 78-79
1979 NA50 A CARBURETOR 79-80
1979 NC50 A CARBURETOR (2)
1979 PA50I A CARBURETOR
1979 PA50II A CARBURETOR
1979 Z50R A CARBURETOR
1980 C70 A CARBURETOR
1980 CT110 A CARBURETOR
1980 CT70 A CARBURETOR 80-81
1980 NA50 A CARBURETOR 79-80
1980 NC50 A CARBURETOR 80
1980 PA50II A CARBURETOR
1980 XL80S A CARBURETOR 80-82
1980 Z50R A CARBURETOR
1981 C70 A CARBURETOR
1981 CT110 A CARBURETOR
1981 CT70 A CARBURETOR 80-81
1981 NA50 A CARBURETOR 81
1981 NC50 A CARBURETOR 81
1981 NX50M A CARBURETOR
1981 PA50II A CARBURETOR
1981 XL80S A CARBURETOR 80-82
1981 Z50R A CARBURETOR
1982 C70 A CARBURETOR
1982 CT110 A CARBURETOR
1982 CT110 AW CARBURETOR
1982 CT70 A CARBURETOR 82
1982 MB5 A CARBURETOR
1982 NC50 A CARBURETOR
1982 NC50 AA CARBURETOR
1982 NU50 A CARBURETOR
1982 NU50 AA CARBURETOR
1982 NU50M A CARBURETOR
1982 NU50M AA CARBURETOR
1982 NX50M A CARBURETOR
1982 PA50II A CARBURETOR
1982 XL80S A CARBURETOR 80-82
1982 Z50R A CARBURETOR
1983 C70 A CARBURETOR
1983 CT110 A CARBURETOR
1983 NC50 A CARBURETOR
1983 NC50 AA CARBURETOR
1983 NU50 A CARBURETOR
1983 NU50 AA CARBURETOR
1983 NU50M A CARBURETOR
1983 NU50M AA CARBURETOR
1983 PA50II A CARBURETOR
1983 XL80S A CARBURETOR 83-85
1983 Z50R A CARBURETOR
1984 CT110 A CARBURETOR
1984 XL80S A CARBURETOR 83-85
1984 Z50R A CARBURETOR
1985 XL80S A CARBURETOR 83-85
1985 XL80S AC CARBURETOR 83-85
1985 Z50R A CARBURETOR
1986 CT110 A CARBURETOR
1986 CT110 AC CARBURETOR
1986 Z50R A CARBURETOR
1986 Z50RD A CARBURETOR
1987 Z50R A CARBURETOR
1988 Z50R A CARBURETOR
1988 ZB50 A CARBURETOR
1989 Z50R A CARBURETOR
1990 NS50F A CARBURETOR
1991 Z50R A CARBURETOR
1992 Z50R A CARBURETOR
1993 Z50R A CARBURETOR
1994 Z50R A CARBURETOR
1995 Z50R A CARBURETOR
1996 Z50R A CARBURETOR
1997 XR70R A CARBURETOR
1997 Z50R A CARBURETOR
1998 XR70R A CARBURETOR
1998 Z50R A CARBURETOR
1999 XR70R A CARBURETOR
1999 Z50R A CARBURETOR
2000 XR50R A CARBURETOR
2000 XR70R A CARBURETOR
2001 XR50R A CARBURETOR
2001 XR70R A CARBURETOR
2002 XR50R A CARBURETOR
2002 XR70R A CARBURETOR
2003 XR50R A CARBURETOR
2003 XR70R A CARBURETOR
2004 CRF50F A CARBURETOR
2004 CRF70F A CARBURETOR
2005 CRF50F A CARBURETOR
2005 CRF70F A CARBURETOR
2006 CRF50F A CARBURETOR
2006 CRF70F A CARBURETOR
2007 CRF50F A CARBURETOR
2007 CRF70F A CARBURETOR
2008 CRF50F A CARBURETOR
2008 CRF70F A CARBURETOR
2009 CRF50F A CARBURETOR
2009 CRF70F A CARBURETOR
1983 NB50M A CARBURETOR
1983 NH80MD A CARBURETOR
1984 NB50M A CARBURETOR
1984 NH125 A CARBURETOR
1984 NH80MD A CARBURETOR
1984 NN50MD A CARBURETOR
1984 NQ50 A CARBURETOR
1984 NQ50 AA CARBURETOR
1985 CH80 A CARBURETOR
1985 CH80 AC CARBURETOR
1985 NB50M A CARBURETOR
1985 NH80 A CARBURETOR
1985 NQ50 A CARBURETOR
1985 NQ50 AA CARBURETOR
1986 CH80 A CARBURETOR
1986 CH80 AC CARBURETOR
1986 NQ50 A CARBURETOR
1986 NQ50D A CARBURETOR
1987 CH80 A CARBURETOR
1987 CH80 AC CARBURETOR
1988 CH80 A CARBURETOR
1988 CH80 AC CARBURETOR
1988 SA50 A CARBURETOR 88-93
1988 SB50 A CARBURETOR
1988 SB50P A CARBURETOR
1989 CH80 A CARBURETOR
1989 CH80 AC CARBURETOR
1989 SA50 A CARBURETOR 88-93
1989 SB50P A CARBURETOR
1990 CH80 A CARBURETOR
1990 CH80 AC CARBURETOR
1990 SA50 A CARBURETOR 88-93
1990 SB50P A CARBURETOR
1991 CH80 A CARBURETOR
1991 CH80 AC CARBURETOR
1992 CH80 A CARBURETOR
1992 CH80 AC CARBURETOR
1992 SA50 A CARBURETOR 88-93
1993 CH80 A CARBURETOR
1993 CH80 AC CARBURETOR
1993 SA50 A CARBURETOR 88-93
1994 CH80 A CARBURETOR
1994 CH80 AC CARBURETOR
1995 CH80 A CARBURETOR
1995 CH80 AC CARBURETOR
1996 CH80 A CARBURETOR
1996 CH80 AC CARBURETOR
1997 CH80 A CARBURETOR
1997 CH80 AC CARBURETOR
1998 CH80 A CARBURETOR
1998 CH80 AC CARBURETOR
1999 CH80 A CARBURETOR
1999 CH80 AC CARBURETOR
2000 CH80 A CARBURETOR
2000 CH80 AC CARBURETOR
2001 CH80 A CARBURETOR
2001 CH80 AC CARBURETOR
2002 CH80 A CARBURETOR
2002 CH80 AC CARBURETOR
2003 CH80 A CARBURETOR
2003 CH80 AC CARBURETOR
2004 CH80 A CARBURETOR
2004 CH80 AC CARBURETOR
2005 CH80 A CARBURETOR
2005 CH80 AC CARBURETOR
2006 CH80 A CARBURETOR
2006 CH80 AC CARBURETOR
2007 CH80 A CARBURETOR
2007 CH80 AC CARBURETOR
