Page 1 of 2
This is how it's done my children.
Posted: Wed Jul 20, 2011 12:09 am
by benjammer112
this is how it's done, 6.5 hp motor bolted to the floor board with some welded on pulleys, the coolest/lamest deathtrap ever.
Re: This is how it's done my children.
Posted: Wed Jul 20, 2011 12:14 am
by wood10214
Look scary to me :nervous:
Posted: Wed Jul 20, 2011 8:24 am
by fastplastic
wow epic fail good luck :crazy:
Posted: Wed Jul 20, 2011 8:44 am
Dude! Swap in a Briggs and Stratton!!
Does it function? If so it is the coolest resurrection ever! Maybe install some footpegs somewhere...
Posted: Wed Jul 20, 2011 11:00 am
by dun rite
Inventive. i'd suggest a belt guard though :smile:
Posted: Wed Jul 20, 2011 12:42 pm
Footpegs??..........belt guard??..........Naw, man.....what it needs is a bottle.......... :bowrofl:
Posted: Wed Jul 20, 2011 1:54 pm
by Palero2003
Thinking outside of the box I guess lol. But if works right on!
Posted: Wed Jul 20, 2011 3:04 pm
Belt guard+++
Looks like the OEM engine still has it's intake and carb. Are you running the injection pump to oil the case bearings?
If the piston/cyl is intact, a check valve in place of the spark plug and plumbing would make a low output/low pressure compressor. Maybe enough to drive an air brush and paint itself - or run a set of air horns.
Posted: Wed Jul 20, 2011 7:19 pm
Quoth The Mouse:
Now ah don' care who y'are or how much money ya got, tha's some funny stuff rat thar! :)
At 9:1 compression ratio, you'd have something like 135PSI. It could keep its own tires inflated too!
You do make a good point about keeping the bearings lubed, but I guess one could lose the connecting rod and piston altogether and just squirt some oil down the plug hole once in a while.
Posted: Wed Jul 20, 2011 9:29 pm
I nominate this for an award....."Best Innovative Thought".......makes me sit back wonder what kind of mind was at work to think this one up......Rah!.....Rah!.....Rah!.. :woot:
Posted: Thu Jul 21, 2011 12:51 am
by maddog
you are now qualified to work at a John Deere plant :smile:
Posted: Thu Jul 21, 2011 7:38 pm
by fastplastic
maddog wrote:you are now qualified to work at a John Deere plant :smile:
:thumbwink:
Posted: Thu Jul 21, 2011 9:02 pm
:thumbwink:
First time I have ever seen Maddog say anything I could agree with.
Posted: Thu Jul 21, 2011 9:48 pm
by Trafficjamz
I hope this was meant to be a joke.
There is no way this piece of $hit runs or moves.
The front pulley is a clutch mounted backwards :confused: with no nut to hold it in place.
The clutch pucks are just flinging around all over the place, with no bell to keep them from flying off.
Posted: Thu Jul 21, 2011 10:04 pm
Suddenly TrafficJamz = Buzzkill! :)
The front engine would make a hellova Dio starter.
