Page 1 of 2
New Builds Spree&89Elite E
Posted: Tue Jul 26, 2011 8:22 am
by Dakine
Planning on Painting Frames. Building Some motors...More Details Laters... But Ima Get Some Pics up..
Planning on doing 1 Brand New af16 motor.. and Building one of my dd50 Blocks... Probably going to build 2 72cc motors...
af16
Debating On A Cast Iron Or Aluminum Mallosi Bore.
Mallosi Full Counter weight Stock Stroke Crank or Stock sa50 Crank
17-24mm Carb
Koso Small or Ct Chrome Manifold
Sef/Daytona Ramp plate,Keli Pulley, Daytona Weights
Zx Clutch
Oil Plug
Semi New Sef Majik Exhaust
Af16 or DD Block Still Debating
Polini Corsa
Stock Crank or Sef Fully counter weighted mini stroke copy crank
Stock Carb With Airbox
Sef/Daytona Ramp Plate,Keli Pulley
Debating on which clutch to run. Either Stock S,Zx, Or Keli Clutch
Oil Plug
Krs Small Exhaust
These Are just my motor Ideas any advice would be very helpful. Havent gotten most of the parts yet..
Planning On Porting The Blocks But not to sure about porting the bores... Any Advice? The Stock af16 Boost port Is polinis recommendation for the corsa right? Or Should I Match Ports even for the mallosi?
Re: New Builds Spree&89Elite E
Posted: Tue Jul 26, 2011 9:14 am
by Dakine
Posted: Tue Jul 26, 2011 9:33 am
by sprite2011
Lucky you parts are located down the street. Lol!
Posted: Tue Jul 26, 2011 10:00 am
by Dakine
haha yea.. Seriously!! Theres Alot of shops in the area but I only take my business to one shop which is glenns cycles. Hes in it for the riders and not the money.
Alot of these parts are hard to obtain the shops usually dont carry the rare parts unless someone brings it in.
Posted: Tue Jul 26, 2011 10:15 am
by sprite2011
I used to live there in Hawaii but wasn't really into moored back in the day. Grew up in Pearl City.
Posted: Tue Jul 26, 2011 10:41 am
by Dakine
oh haha ha come to young? Oh dayumn das on the other side of the island!
What made you get into the scene?
Posted: Tue Jul 26, 2011 10:59 am
by sprite2011
My work is 10 minutes away from my house and I'm tired of driving my car. I have a motorcycle.too but its not fun riding.around traffic. So, got me a moors and the law here does not require you to register the vehicle but 35-40 is the speed limit. Lol! Besides this is way cheaper to build than my other hobbies. Where are you, Kaneohe? Since you said the other side.
Posted: Tue Jul 26, 2011 10:37 pm
by sum-azn-kid
so you bought that cherry pal. i remember seeing that on fh a while back. good luck with your build. but why build 2 72s? id do a 72 and a full stroker.
Posted: Tue Jul 26, 2011 10:48 pm
by Dakine
Huh bought This cherry pal? Didnt buy this from no one... Mayb the pannels but thats it... Cause you can build an animo 72 that keeps up with strokers... Ah stroker just doesnt seem to catch my eye..
EDIT. The pal you are talking about had ah stroker on it already
Posted: Wed Jul 27, 2011 12:50 am
by sum-azn-kid
my bad i thought it was Jon's pal. btw it that a real sef majik or the copy?
Posted: Wed Jul 27, 2011 1:22 am
by KingJeff801
Dakine wrote:haha yea.. Seriously!! Theres Alot of shops in the area but I only take my business to one shop which is glenns cycles. Hes in it for the riders and not the money.
Glenns is the Bomb, does Butch Hee still work there? I used to live down the street from there, back when dio's were first coming to america.
Posted: Wed Jul 27, 2011 1:25 am
by Dakine
yeais isn't jons pal but he did hook me up wit some tail lights and pannels he's ah pretty cool Guy if u meet him.
yep Glenn is da man and ya he still works there with Glenn.
Posted: Wed Jul 27, 2011 1:28 am
by Dakine
that would be the realsef majik the copy hugs closer. to the wheel and I don't think it has the kanji. on iy
Posted: Wed Jul 27, 2011 5:30 pm
by Dakine
So im going to pick up a Mhr Aluminum bore kit and a Polini Corsa today...
Should I match both boost ports on the blocks to the bores? Both Bore Kits are going onto af16e Blocks. I know for ah fact im going to open up and clean up the intake port on the block.. But what do you guys think about the boost ports? Should I match ports on both blocks?
Posted: Wed Jul 27, 2011 5:53 pm
by iRiE S0ULJAH
for da corsa jus leave da af16 boost alone because you can staright bolt um on n it already match
and for da malossi aluminum port da af16 boost to da malosssi aluminum boost becuz its kinda bigeer den da corsa.
jus port both intakes on your 2 block.
