Need Help malossi leaking base gasket
Posted: Sat Jul 30, 2011 4:12 pm
by HI808SYM
so the other day i decided to test for intake leaks using carb cleaner around the manifold to case and cylinder to case (i dont know if that was the correct way to do it but i was very gentle with the spraying)
anyway found that when i sprayed between the manifold and the cylinder the bike would die out.
Re: Need Help malossi leaking base gasket
Posted: Sat Jul 30, 2011 5:14 pm
by z50r-ghost
Your bore isn't touching your intake manifold, is it? I had a stage 6 (Koso) intake mani that set right against my corsa bore... What gasket are you using; paper or aluminum? I always coat my gasket surfaces in a very light coat of hondabond before installing...
Posted: Sat Jul 30, 2011 5:57 pm
by dun rite
I had to remove some material from my intake as well, to let the cyl. fit flat. but that was on a 50mm tazland001 bore.
Posted: Sat Jul 30, 2011 6:08 pm
by Dakine
Hmm. You sure theres no cracks at the base of the bore? or in your intake manifold or the block from tightening it to much? It shouldnt be the actual gasket thats the problem..What kind of block are you using?
What area do you live? Maybe could check it out.
Posted: Sat Jul 30, 2011 7:29 pm
by bradthreee
x2 for the Hondabond or I sometimes used the copper RTV sealant...
Posted: Sun Jul 31, 2011 6:13 pm
by HI808SYM
thanks for all the input.
Posted: Sun Jul 31, 2011 6:58 pm
by dun rite
probably need to put heli coils in place of stripped threads. Even if the torque wrench clicks at 8. Since it won't click at 10 the threads are pretty much gone, and will probably give you problems down the road.. don't know if drilling and tapping to a 1/4x28 would work or not.
Posted: Mon Aug 01, 2011 6:23 pm
by HI808SYM
dun rite wrote:probably need to put heli coils in place of stripped threads. Even if the torque wrench clicks at 8. Since it won't click at 10 the threads are pretty much gone, and will probably give you problems down the road.. don't know if drilling and tapping to a 1/4x28 would work or not.
.what is that? how does it work? and where can i get it? .
i really dont want to have to replace my block
thanks
Posted: Mon Aug 01, 2011 6:25 pm
I Googled Heli-Coil. You can too!
:wink:
Posted: Wed Aug 03, 2011 7:37 am
by Spreetard
Wheelman-111 wrote:Greetings:
:wink:
LIES! You Bing'd it! :geekdance:
