1998 Honda Elite SA50P
Stock 49cc piston with excellent compression
Stock variator (with the restrictor plate removed)
Stock rollers
Stock clutch
Stock carburetor (with a 78 main jet)
Stock oil pump ("tied open")
Stock gear ratio
Stock muffler (de-restricted, opened up inlet)
My current combo runs great and tops out at about 40mph (my estimation, since the speedo pointer is past the 35mph max reading).
But I want to put this cool looking YMS pipe on!
I did try it, but I completely lost my bottom end power.
My goal is to use this YMS pipe and keep as many stock parts as I can - with maybe only a re-jet. Has anyone had any experiences with a YMS V8 28mm pipe using a stock carb and piston, or am I going to need to go with a larger (OKO?) carb and piston?
Please don't bark at me to check the forums - I searched for an answer and really was not able to draw any clear conclusions...so I am asking if any one has had good success with this pipe with minimal changes from stock (for the other components).
My preference while using this YMS pipe would be: a quick take off and a 45-50mph top end (I am not looking for top speed, but rather good out-of-the hole and mid range power). I am ready to dig in and make any changes necessary to make this pipe work, but I prefer to keep it simple and not "reinvent the wheel"!
Whatever recommendations are made, I will implement them and provide feedback on this forum for future users to learn from...I won't ask a bunch of posted questions/dialogue then quietly disappear after I have a great running combo. I hate it when I see that happen....
I appreciate your input!
