How to tell if auto lube is working...
Kemmer
Post by Kemmer »
I'm worried that the autolube on a recently aquired Aero 50 isn't working. How to I tell?
I might be disabling it down the road anyway, but for now I'd like to make sure.
Also, how exactly do I go about disabling it? Just unhook the oil tank, plug the hole and premix?
myhonda
Post by myhonda »
how to tell. im not to sure myself. i boght clear lines so i can see if the oil is going where its sposed to.
With the engine idling, unplug the oiler from manifold. You should get a drop every 5-10 seconds.
To disconnect, just cap all the lines and run premix.
Kemmer
Post by Kemmer »
Cool, I'll check it tonight after I do my carb rebuild.
Grimloc
How to bleed the line?
Post by Grimloc »
Probably really simple, but I haven't done maintenance much. If I disconnect the oil line....how does one "bleed" the air from it?
'86 Spree....Not yet running.
Farfignugin
Post by Farfignugin »
look in manual, it should tell you there.
hondaman
Post by hondaman »
If you just disconnect the oil line from the manifold to see if oil is coming out you do not have to go through the whole process of bleeding the lines.
On the other hand if oil does not come out when the engine is running then you may have air in the lines. Then you will have to bleed the air from the lines.
bfizzle
Post by bfizzle »
An easy way to see is to run premix and your injector at the same time. Put a piece of tape where the oil level is and burn through a tank or two. IF the oil level drops the injectors are working.
mopedman
Post by mopedman »
yea but if you did that and it wasn't working you could burn up your moped
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
bfizzle
Post by bfizzle »
mopedman wrote:yea but if you did that and it wasn't working you could burn up your moped
That is why you run premix at the same time. Running a little rich on the oil will not hurt anything during the couple tanks you use.
