Will these tires fit a Spree?
We're talkin' contact patch now............
- rucks.jpg (9.85 KiB) Viewed 5275 times
- Trafficjamz
Re: Will these tires fit a Spree?
Yes, those should fit a spree with no problems at all.
Trafficjamz wrote:Yes, those should fit a spree with no problems at all.
however,
- martynkim
What part on the Spree do you want the tires to fit?
just a little fender trimming .....lol
Did I say Spree?....I meant Gyro.......
- gyro 3.jpg (28 KiB) Viewed 5202 times
- mopro logan
I think they would go good on the spree. But might fit the gyro just a little better.
- bradthreee
How many mm is the brake hub for the Gyro? How many spline count?
b3.....lacking accurate instrumentation, but the closest I can measure indicates that brake hub inside diameter = 80 mm........shaft is 19 spline count, diameter of shaft = 13 mm
Would look good on a Gyro.
The later model Gyros have hub adapters B3 found in Japan awhiile back.
When 66Six cruises by this thread, maybe he's checked if rear hubs from his Gyro UP fit up on a TG50? Another question: Is the bolt circle the same on the UP wheels as the TG50?
